jakubk
Joined: 5/4/2008 From: Warsaw, POLAND Status: offline
quote:
ORIGINAL: gbarnes27 Guys, I have been reading all the posts here but did not see what I was looking for and I need some advice. This will be my first gas / nitro plane. I have ordered the DL-50 but need to find out what batteries I need or can use. I have heard that lipo is good cause its lighter and I have also heard that the A123 batteries are good because they don't lose a charge just sitting there when everything is off. If I want to go with a lipo setup on the ignition and radio then what all do I need? I appreciate all the help in advance. I cant wait to get this big bird in the air. Greg. Greg, In my Yak 88 DA 50 I use Lipo 7,4V 1500 mAh for ignition with Smart switch from PowerBox - switch with regulator out voltage is 5,5V. For receiver I use 2xLiIon 2600 mAh(TBM) with PowerBox sensor - manager with double regulator - out volatge is 5,9V. This working very good. Regards Jakub
_____________________________
Regards Jakub
