RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Flight-Model Yak-55 50cc - ARF
Seller:  Hover259
Details:   $549.00   |  10/29/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  87 88 [89] 90 91 92 93 94 95 96   next >   >>
Login
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 6/27/2009 2:54 AM
propchief
Score: 100
Last Login: 11/8/2009
Status: offline
I've got a very small amount and it seems to roll very straight however every time I take it out it's either too windy to get it checked correctly or I end up having too much fun flying and end up "goofing around" for the flight. More often the later but it sure puts a grin on your face.
Just check my Tx settings and it's 10% differential ... if you need the degree I'll have to measure the ailerons.
< Message edited by propchief -- 6/27/2009 1:12 PM >
Hide Signatures
(in reply to JoeAirPort)
       Post #: 2201
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 6/27/2009 5:53 PM
JTFDEZ
Score: 100
Last Login: 11/5/2009
Status: offline
Thanks Propchief
You confirmed my theory that differential ailerons is needed.
I had a doubt because a friend at the field has a YAK 88" and my impression is that my extra "track" better but his yak roll more axial.
I'll be glad if any one can give me some "start point" about surface deflection, just to compare.....
JTF
Hide Signatures
(in reply to propchief)
       Post #: 2202
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/2/2009 2:46 PM
gbarnes27
Score: 100
Last Login: 11/2/2009
Status: offline
Hey guys,
HEATWAVE IN THE HEARTLAND in Tulsa weekend of July 24th. We usually have between 80 and 100 Pilots(+ 3,000 spectators), and many will be arriving early for some weekday hucking, get there soon for a good spot! The event is for all big planes, so if it's big and has wings, bring it!
More info. at www.tulsagluedobbers.com
This will be the first event that I will have participated in and will be representing my Extreme Flight Extra
Youtube video of the 2006 and 2007 Heatwave. I cant find the video for the 2008.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by gbarnes27 -- 7/2/2009 3:04 PM >
Hide Signatures
(in reply to JTFDEZ)
       Post #: 2203
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/2/2009 8:16 PM
RodanAZ
Score: 100
Status: offline
Had my canopy blow off in flight the other day!
Later examination leads me to believe one of the screws vibrated loose, and the resultant flutter caused the structure on the other side to fail. It scared the crap out of me at first, as I initially thought I lost either the rudder or one of the stabs. It was a ways out and pretty high at the time. I just kept flying it, and when I got it straight and level, I could see it was the canopy. I landed without any issues, and actually beat the canopy to the ground! It fluttered down like a leaf, and didn't receive any damage from the fall. Fortunately someone watched it come down for me, so we knew exactly where it landed...
Should be an easy repair job... going to try to get to it this afternoon...
Hide Signatures
(in reply to gbarnes27)
       Post #: 2204
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/2/2009 8:35 PM
gbarnes27
Score: 100
Status: offline
That would scare the crap out of me if that happened to me. Glad that you got it down with no problem.
Greg
Hide Signatures
(in reply to RodanAZ)
       Post #: 2205
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/2/2009 8:50 PM
JoeAirPort
Score: 115
Status: offline
One of my screws vibrated loose too. When the screw finally fell out somebody watching me fly heard a pop which I think was one side of the canopy lifting. I landed and had a little crack to the canopy from lifting only on one side. Fixed it with canopy glue and some same color covering over the tiny crack. Can't even see it. In fact I forgot about it until I read your post. Now I use a little blue lock tite on my canopy screws. Probably not necessary but it makes you paranoid after these things happen. A new canopy shipped is not cheap.
_____________________________
Joe AP
Hide Signatures
       Post #: 2206
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/3/2009 2:21 AM
propchief
Score: 100
Status: offline
Try using a 10-24 nylon bolt for the canopy. You can drill/tap the existing holes and don't have to worry about them comming loose. I have them on mine and no problems ... in fact the last three gassers without any loosening.
Hide Signatures
       Post #: 2207
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/3/2009 2:35 AM
xtraflyr
Score: 100
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: propchief
I guess that's why they use Nylon bolts for the wingsless prone to back out ?
www.njjf.org
www.njjf.freeforums.org
Hide Signatures
       Post #: 2208
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/3/2009 2:36 AM
cjcyclesrc
Score: 100
Status: offline
I haven't had any problems with the factory bolt and bonded washer.
Charles
Hide Signatures
       Post #: 2209
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/3/2009 1:28 PM
propchief
Score: 100
Status: offline
quote:
ORIGINAL: xtraflyr
quote:
ORIGINAL: propchief
I'm not sure if that's the reason but they work great. Also the profile of the nylon bolts is about the same as the bolts with the washers.
Hide Signatures
(in reply to xtraflyr)
       Post #: 2210
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/7/2009 8:03 PM
craigteffe
Score: 100
Status: offline
Which hole in the rudder control horn are you guys using? Are you crossing your cables?
Craig
Hide Signatures
       Post #: 2211
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/7/2009 8:45 PM
cjcyclesrc
Score: 100
Status: offline
quote:
ORIGINAL: craigteffe
The outer ones.
Yes, I got the best results with the cables crossed with a 4" SWB offset arm.
Charles
Hide Signatures
(in reply to craigteffe)
       Post #: 2212
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/7/2009 9:17 PM
JoeAirPort
Score: 115
Status: offline
Same here.
Joe AP
Hide Signatures
(in reply to cjcyclesrc)
       Post #: 2213
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/9/2009 4:05 AM
craigteffe
Score: 100
Status: offline
Thanks for all your help!
I have another question, The manual does not match the tail wheel that i got with my kit it has the springs instead of the tilller arm could one of you guys that have this same setup post some pics of the tail wheel layout? It seems the tail wheel brckt does not go back far enough for the springs to work .
Craig
Hide Signatures
       Post #: 2214
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/9/2009 6:20 AM
cjcyclesrc
Score: 100
Status: offline
You're welcome. I'm still running the old style tail wheel on my plane. Here is a picture of the one on my 110" Yak. Hope this helps.
Click for fullsize
Charles
Hide Signatures
       Post #: 2215
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/9/2009 2:03 PM
JoeAirPort
Score: 115
Status: offline
Put the tail wheel bracket as far back on the fuse as you can and the T bar as far forward on the rudder as you can....but make sure they don't hit each other at each end of deflection. That worked for me. This is the 88" Yak but same assembly.
Click for fullsize
Click for fullsize
Click for fullsize
Joe AP
Hide Signatures
       Post #: 2216
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/13/2009 8:25 PM
RodanAZ
Score: 100
Status: offline
Well, the inevitable happened, and I experienced a simultaneous lack of airspeed and altitude...
The damage was limited to the canopy, cowl, and motor box, and the top of the rudder. The wings and stabs didn't get a scratch. Unfortunately, it basically sheared the whole motor box off the firewall:
This is my first big gasser, and I'm a little worried about the strength of a repair in this area. The sides of the motor box are continuations of ply pieces that run all the way back past the wing tube, and I'm wondering if a repair will hold up.
I'm considering using carbon strips to 'splint' the pieces back on, and use triangular pieces in front of the firewall as braces. What do y'all think?
I really hate to have to buy a new fuse, because this is the only damage, and with the cowl, canopy and shipping, it will push the cost of the crash to nearly the level of a new airframe...
Hide Signatures
       Post #: 2217
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/13/2009 8:48 PM
JoeAirPort
Score: 115
Status: offline
Fix it !!! If you know a guy who has built kits and done repairs get him to give you tips how to fix it. I did this and was amazed at the advice he gave me. Basically you can double the shear points with new ply and probably glass and /or CF. My guess is that it will add less than a half pound and be way stronger. Getting it straight will be the trick. Again, a kit guy is your best friend right now. He knows how to make straight planes out of sticks.
Joe AP
Hide Signatures
       Post #: 2218
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/13/2009 10:45 PM
propchief
Score: 100
Status: offline
Easy to fix, especially if you have the original parts to put back into place. Then it's a matter of getting the joints spliced to provide strength. Ask around and you'll find someone out there that can walk you through it.
Hide Signatures
       Post #: 2219
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/14/2009 8:59 AM
freeair
Score: 101
Last Login: 10/31/2009
Status: offline
i think you need to epoxy another front bulkhead over this useless piece of wood and make up a good strong engine box to suit.
Hide Signatures
       Post #: 2220
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/14/2009 2:18 PM
JoeAirPort
Score: 115
Status: offline
Show us a pick of the other half. Also how did so much exhaust oil get all over the engine box?
Joe AP
Hide Signatures
(in reply to freeair)
       Post #: 2221
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/14/2009 11:05 PM
Pale_aileron
Score: 100
Last Login: 10/18/2009
Status: offline
This is where the hobby gets creative. you should chuck it though... I'll give you $5.00 for it :-)
Hide Signatures
       Post #: 2222
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/17/2009 5:10 PM
JoeAirPort
Score: 115
Status: offline
Wassup?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Joe AP
Hide Signatures
(in reply to Pale_aileron)
       Post #: 2223
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/21/2009 12:09 PM
James O
Score: 100
Status: offline
Hey guys, need a lil help trying to work out which ultracote i need for my yellow n blue extra ...
i tried searching through out the thread, I know its been posted some where but for the life of me cant find it
Thanks in advance
James...
Hide Signatures
       Post #: 2224
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 7/27/2009 2:59 AM
propchief
Score: 100
Status: offline
quote:
ORIGINAL: JoeAirPort
Wassup?
Between work, my son, and vacation I got out today for the first time in over 4 weeks. Despite the windy conditions I put in 3 good flights. Dialed my expo down from 10% to 5% and it seemed to be just a little shy of rolling completely axial. I'll try 7% next time out. The plane really grooves and I spent a lot of time going from inverted flats spins to inverted harrier. Trying to work them lower! The plane makes it easy and looks really sharp.
James - I have the red/white/blue one so I can't help with the colors. I'm sure a quick e-mail to EF will get you the answer.
John
Hide Signatures
       Post #: 2225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.359RCU1
