RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Composite-ARF Extra 260 3m
Seller:  doolittles
Details:   $4,500.00   |  11/19/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
Page: <<   < prev  87 88 89 90 91 92 93 94 95 [96]
Login
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 10/29/2009 2:53 PM
cjcyclesrc
Score: 100
Last Login: 11/21/2009
Status: offline
quote:
ORIGINAL: jsenicka
Hey
Can I ask the experts on best electronics load out for the 88'' EF Extra ?
I currently have 4x HS5945MG for aileron and elevator set aside, and a 5955TG for rudder.
I also have a set of 4 8611 I could use on A/E, but wanted to hold those for another project if possible.
Are 5945MG enough for solid 3D control on aileron and rudder?
Absolutely. The 5945 on the Ailerons and Elevators will be fine. The 5955 is perfect for the rudder. I ran 5985's on the ailerons and elevators of my 88" Yak and never had any trouble.
IMO the best set up now is 5) 7955's if purchasing new, but If you already have the 5945's I would use them.
_____________________________
Charles
Hide Signatures
(in reply to jsenicka)
       Post #: 2376
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 10/29/2009 2:58 PM
JoeAirPort
Score: 115
Status: offline
I agree, no problem. I had that same exact setup on two different 50cc 3D gassers. It worked great.
Joe AP
Hide Signatures
(in reply to cjcyclesrc)
       Post #: 2377
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 5:36 AM
leepord geko
Score: 105
Status: offline
Well along time ago on this thread I said I was going to get one of these and despite not going that route it looks as if I might in the end, because my Aeroworks Extra is definatly done http://www.youtube.com/watch?v=ZGOETNdHSZ8 , can you fit this plane in the back of a half ton truck with a regular box with out the gate down? I wasn't all that impressed with the flight characteristics of the aeroworks, so I may go this route.
Once you have a yak you''''ll never go back! Until THE EXTRA 300 CAME ALONG!
Hide Signatures
       Post #: 2378
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 2:14 PM
propchief
Score: 100
Status: offline
If I can get mine into a Toyota Prius then I'm sure the pickup will work. I saw a 40% in the back of a Ford Ranger ... the pilot built an extension to make it long enough and make sure everything was secured. That worked very well for him.
Any details on the cause of your lock-out? What was the aircraft power set-up?
Hide Signatures
(in reply to leepord geko)
       Post #: 2379
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 4:08 PM
JoeAirPort
Score: 115
Status: offline
quote:
ORIGINAL: leepord geko
I was going to recommend the EF Extra when I saw your video. It's probably the best one out there. If you remove your spinner and turn your rudder that will buy you some space. It'll probably fit though. Do you need some measurements from me? Just say the word.
PS: It's a harrier monster. I'm doing them all the time on this Extra . Incredible harriers. No wing rock.
Joe AP
Hide Signatures
       Post #: 2380
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 5:11 PM
leepord geko
Score: 105
Status: offline
I want to get it after jake ruddys review and he still thinks its the best 50cc out there, and I would like a plane that can harrier like my funtana or at least close, because the aeroworks sure wasn't stable enough. I was going to go imac as well so I'm not sure about getting the edge 540 from ef. The power setup was a smart fly sport plus with 2 fromeco 2600 batteries, and they weren't plugged into the batter/bind port because I already knew about that. I think there's something wrong with the radio, anyways I'm sending all my receivers and the radio back to spectrum to get checked up. Whats the total length with no spinner, I'm wondering if I can go diagonally in the truck.
Hide Signatures
(in reply to JoeAirPort)
       Post #: 2381
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 10:23 PM
propchief
Score: 100
Status: offline
Just measured 84" without the spinner. This is the plane for IMAC. It really presents well in the air and flies a very precise line. Thanks for the info on the radio failure and sorry about the loss of the plane.
Hide Signatures
       Post #: 2382
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 10:57 PM
JoeAirPort
Score: 115
Status: offline
Mine's 86" with True Turn 4" P51 spinner. Without the spinner it looks right about what propchief said (I didn't remove the spinner). You can also turn the rudder and push the elevators down to buy yourself 2-4". I do this on my Yak and Extra . There are always little tricks that can save some space. You can remove stab's too.
Joe AP
Hide Signatures
(in reply to propchief)
       Post #: 2383
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/8/2009 11:33 PM
ISSUES
Score: 100
Last Login: 11/15/2009
Status: offline
If it's a full length bed it should fit no problem. Mine rides in the back of the Suburban which is 8'.
I'm still loving this plane! I've only used the Xoar 22x10. Has anyone used the 22 3DA? (I'm flying DLE 55)
Hide Signatures
       Post #: 2384
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 12:32 AM
leepord geko
Score: 105
Status: offline
Its a standard box so only 6', I was using a Vess 23B in that video I posted of the now old Extra and It pulled much better than the xoar 22x10 I had on before. Also what were you guys getting for weight on this plane?
Hide Signatures
(in reply to ISSUES)
       Post #: 2385
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 3:33 AM
JoeAirPort
Score: 115
Status: offline
17#, 10 oz. No pilot or instrument panel. Flies VERY light at this weight.
Joe AP
Hide Signatures
       Post #: 2386
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 1:22 PM
propchief
Score: 100
Status: offline
I've got to be a bit heavier than JoeAP with a cannister and pilot and dash panel installed. Don't have a number because ... well it's a long story. :-) Anyway, the plane flies very well and the performance is limited only to my abilies. Using a Zoar 23x8 laminated.
Hide Signatures
       Post #: 2387
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 3:12 PM
JoeAirPort
Score: 115
Status: offline
This Extra is larger than the Aeroworks so it's not really in the same size class. I would call them "over-sized" class of 50cc air frames. My EF 88" Yak is huge. Most people ask if I have an 80cc in it. When I say 50cc they stand there dumbfounded. :-)
Joe AP
Hide Signatures
       Post #: 2388
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 5:03 PM
mm
Score: 100
Status: offline
hello joe,
do you prefer your yak or extra ?
thank's
Stephane
Hide Signatures
       Post #: 2389
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/9/2009 6:18 PM
JoeAirPort
Score: 115
Status: offline
The both 3D awesome. But if you want it for precision, the Extra carries more speed through the manuevers. I like them both.
Joe AP
Hide Signatures
(in reply to mm)
       Post #: 2390
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/10/2009 7:08 PM
mm
Score: 100
Status: offline
thank's joe
Stephane
Hide Signatures
       Post #: 2391
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/12/2009 8:30 AM
Marko1
Score: 100
Status: offline
Hello,
I am posting a link where I put foto of my Extreme Frank Extra 88. If you will wisit link you will know why Extreme Frank. I just wont to show what is migt done with wracage, wich can happen very fast in our hooby. Enjoj in looking.
http://forum.modelarji.com/viewtopic.php?t=46074
Marko Frank
Hide Signatures
(in reply to mm)
       Post #: 2392
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/12/2009 12:44 PM
ISSUES
Score: 100
Status: offline
Wow, Great job on the rebuild Marko! Not many would go that far to rebuild an ARF.
Hide Signatures
(in reply to Marko1)
       Post #: 2393
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/12/2009 1:14 PM
JoeAirPort
Score: 115
Status: offline
Yeah nice re-build. I would have trashed it for sure. It looks like new. Are you going to repair the cowling?
Joe AP
Hide Signatures
       Post #: 2394
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/12/2009 10:02 PM
Marko1
Score: 100
Status: offline
That re-build cost me (in time) two model, but i realy love to re-built and bring back the lost spirit to original model. That make me realy good filing, cant wait to fly her. The covling I am going to repair it, i think that this shouldnt be any problem. I already order the new one for just in case.
Marko Frank
Hide Signatures
       Post #: 2395
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/12/2009 10:32 PM
JoeAirPort
Score: 115
Status: offline
I had a little accident too a couple months ago. I pan caked it in doing a "too low" knife edge loop. It could have been so much worse had I not leveled the wings in time and kept them "almost" level. Hence the busted wing tip. The repair was a LOT of little things. It took me a week to get it back in the air. The last picture is the repaired plane.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Joe AP
Hide Signatures
       Post #: 2396
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/14/2009 5:04 AM
JoeAirPort
Score: 115
Status: offline
Looks like I'll be flying this bad boy tomorrow. Looks cloudy but otherwise nice. I've been hucken the Yak for weeks so it'll be nice to take the Extra out again.
Joe AP
Hide Signatures
       Post #: 2397
RE: Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, ... - 11/14/2009 11:29 PM
JoeAirPort
Score: 115
Status: offline
Wow no wind and 3D heaven today at the field. Anybody else love this plane?
Joe AP
Hide Signatures
       Post #: 2398
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.141RCU1
