What engine mount to use on inverted YS63?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> What engine mount to use on inverted YS63?
Page: [1]
Login
What engine mount to use on inverted YS63? - 8/18/2007 11:49 AM
DaveInLA
Score: 100
Last Login: 2/19/2012
Status: offline
Hi, I'm thinking of mounting the older YS63 in an inverted position for a warbird (Kyosho Zero). I've heard that the older engine has a reputation for warping its crankcase using certain mounts, but I'm not clear on which type (aluminum or glass-filled nylon). Can anyone recommend a good engine mount for this engine that won't cause this problem? Is nylon better or aluminum?
Also, in case I choose the 63S model, does it use the same mount?
Hide Signatures
       Post #: 1
RE: What engine mount to use on inverted YS63? - 8/22/2007 9:08 AM
DaveInLA
Score: 100
Status: offline
Nobody?
Hide Signatures
(in reply to DaveInLA)
       Post #: 2
RE: What engine mount to use on inverted YS63? - 8/22/2007 4:36 PM
jwmm
Score: 100
Last Login: 5/22/2013
Status: offline
Hyde mounts do a soft mount for YS 63, also fits 63s.
Dosent require a nose ring fitting.
Hide Signatures
       Post #: 3
RE: What engine mount to use on inverted YS63? - 8/23/2007 6:30 AM
DaveInLA
Score: 100
Status: offline
Does "soft" mount simply refer to glass-filled nylon, or metal mounts with rubber grommets?
Hide Signatures
(in reply to jwmm)
       Post #: 4
RE: What engine mount to use on inverted YS63? - 8/23/2007 8:24 AM
Troy Newman
Score: 105
Last Login: 8/23/2008
Status: offline
I don't know of any issues with the motor mounts warping the case....I have used the nylon glass filled mounts on the 63's and 110's although on the larger engines these mounts are a little weak.
An aluminum beam style mount will be fine also....
On the larger engines I use a Hyde soft mount. These have a rubber isolator and only work in rotational movement. Its not like mounting the engine on rubber bumpers....however there are a couple of rubber bumper mounts out there that will work..
For me personally the normal mounts that come with most kits are fine for the 63's they don't shake too much.
Central Hobbies has hyde mounts and the Dave brown rubber bumper style mounts.
www.centralhobbies.com
Dave brown nylon style mounts work also.
Troy Newman
Team YS
Hide Signatures
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> What engine mount to use on inverted YS63?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
