Cornfused about HSN setting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> Cornfused about HSN setting
Page: [1]
Login
Cornfused about HSN setting - 8/19/2007 1:50:32 AM
Tbone4life
Status: offline
Magnum XLS .15A
The paper work that came with my XLS .15A, says that the engine RPM will increase 10 -30% in the air over that achivable on the ground. this is due to the forward motion of the airplane as well as the aerodynamics of the propeller and the lower levels of fuel in the tank after fly a few minutes. (Basically they say set it rich on the ground).
Since I cant take an rpm reading in flight (due to lack of hobby funds ) has anyone (2Cool) with the electronics in their planes able to read RPM during flight noticed this?
Why does O.S and Satio not mention this in their paperwork?
My XLS .15 with an 8x3 MAS combat prop turns 18,000 RPMs on the ground
18,000 + 10% = 19,800 RPMs
18,000 + 30% = 23,400 RPMs = Ka-Klunk!!!!
_____________________________
Club Saito #540
       Post #: 1
RE: Cornfused about HSN setting - 8/19/2007 5:18:26 AM
AirScharnell
Status: offline
SInce you are spinning the MA 8x3, I will guess you are getting ready for SSC combat?
All engines unload in the air. You are not holding it stationary. ANd im sure that after you get some time on that MAGnum your RPM may go higher.
Frank
(in reply to Tbone4life)
       Post #: 2
RE: Cornfused about HSN setting - 8/19/2007 6:12:21 AM
OzMo
Status: offline
the wings fell off the plane in your avitar
yep a little rich is standard for all glow engines on planes. happy hunting
< Message edited by OzMo -- 8/19/2007 6:13:51 AM >
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to AirScharnell)
       Post #: 3
RE: Cornfused about HSN setting - 8/20/2007 1:56:44 AM
Montague
Status: offline
Like the guys said, all engines unload in the air, and will run leaner than they are set on the ground. The other engine instructions DO say to back the engine off of peak RPM on the ground, they just don't explain exactly why.
In general, the amount you need to richen the needle depends on the engine, airplane, and prop, since different combinations will unload differently in the air, which means the amount the mixture will change varies a lot depending on your setup.
Kirk Montague Adams
RCCA 560
(in reply to OzMo)
       Post #: 4
RE: Cornfused about HSN setting - 8/20/2007 2:02:21 AM
Tbone4life
Status: offline
I never even thought of this happening to the engine, I've cooked a couple of car and truck engines , but that was due to gettin a little to twist happy with the HSN, when I wanted it to go just a "little" faster.
Club Saito #540
(in reply to Montague)
       Post #: 5
RE: Cornfused about HSN setting - 8/20/2007 2:10:28 AM
Montague
Status: offline
Yeah, the mixture can change quite a bit in the air. Also, you'll find that the tank setup is more critical, especially with the smaller engines like the Mag .15XLS. The XLS has a large carb throat, and a large exhaust opening, so it doesn't draw fuel well if you have a bad setup. And it will lean out in a hard turn or sustained climb as well, if you're tank isn't right.
Kirk Montague Adams
RCCA 560
       Post #: 6
RE: Cornfused about HSN setting - 8/20/2007 11:25:00 AM
j.duncker
Status: offline
Assuming you are flying something capable of 75 +mph in the air a 3 inch pitch is low. I fly 12th scale combat and use the APC 7x5 on a OS 15 CVA.
On a 750 gr model the vertical is unlimeted and I am one of the faster kids on the block.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
       Post #: 7
RE: Cornfused about HSN setting - 8/20/2007 2:15:20 PM
Montague
Status: offline
j.duncker,
Since the OP is in Texas and asking about the 8x3, I think it's safe to assume he's flying SSC combat, which, as far as I know, isn't flown over there in the UK. The MAS 8x3 is the manditory prop for SSC, the idea is to keep the speeds down to closer to 55mph, which it does.
Using .15s in a scale combat class is pretty much dead in the USA at this point.
Kirk Montague Adams
RCCA 560
(in reply to j.duncker)
       Post #: 8
RE: Cornfused about HSN setting - 8/20/2007 8:21:24 PM
j.duncker
Status: offline
Rats. I am heading to Texas and I like fast.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.610RCU3
