Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Hi Shortman I've been building and flying for over 30 years now, and one of the best of those days was when CA hinges were invented. I whole heartedly agree with the quantities that Scorpionjack gave you for the flight surfaces. Don,t let the hinge gap get real wide between surfaces, that's what will usually cause any flutter. In my personal opinion, stay away from the Great Planes CA hinges. They cut out an oval in the center of the hinge. I guess they think it makes the CA flow better. My experience is it just weakens the hinge by removing needed material. For more complete wicking of the CA into the balsa, drill a 1/16" hole at the center of each hinge slot and chase the slot with a knife blade after drilling to clean up the slot. Don't let any extra CA run down the hinge line and dry, glueing the surfaces together. Keep a paper towel handy to immediately wipe away any excess glue as you go. Acetone will generally clean up CA, but will sometimes mar Ultracote. It does't seem to effect Monocote, though. If you get a white flash deposit after cleaning up CA with acetone, follow up with a paper towel and alcohol. It usually works. Silversurfer
< Message edited by silversurfer -- Mar 13 2002 6:07AM >
