Aqcuired a new motor!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> Aqcuired a new motor!!
Page: [1]
Login
Aqcuired a new motor!! - 8/19/2007 4:04:55 AM
AS-EE
Status: offline
I have acquired a godly, torquey, motor made by Pitmann. This beast does not require much current to develop tons of torque!! Its current at stall with 24 volts applied is only 17 Amperes which is easily handled by the ESC. The top rotational velocity is 3,500 RPM at 24 volts, so its perfect!!
The only issue is the motor is physically larger than your typical 55t lathe motor. The dimensions are 3 3/4" length by 1 5/8" diameter. The shaft is 1/4" "D" so pinions will be hard to get for this sucker. 1/4 scale or 1/6 scale rock crawlers would be perfect though!
So what do you all think? I have the printed numbers it has on it:
14203C270-R1
24 VDC
12-17-02 (Date code?)
I went to the Pittman website and I could not find this one. I did find the 1400 Series and figured my motor would fall under this section that has "14XX3".
http://www.pittmannet.com/pdf/lcm_bulletin.pdf
The torque is 160 OZ-IN at stall with just 17 amperes!! That is much more torque than many nitros and the 55 turn lathe motor can produce. I am even willing to bet that is more torque than a Johnson 940 series motor used in boat racing.
       Post #: 1
RE: Aqcuired a new motor!! - 8/19/2007 4:13:03 AM
sheograth
Status: offline
Thats a nice motor, Ive used a few of that exact one before, never in an RC though.
_____________________________
www.mangosnake.com
(in reply to AS-EE)
       Post #: 2
RE: Aqcuired a new motor!! - 8/19/2007 4:58:28 AM
AS-EE
Status: offline
You should give it a try. This motor has precise speed control and the cogging is very low. I opened up my motor and the armature has the iron laminates skewed. The wire is small like maybe 24 gauge wire I guess. I really like the fact that the brushes are easy to get to by removing the two side screw caps.
(in reply to sheograth)
       Post #: 3
RE: Aqcuired a new motor!! - 8/19/2007 5:03:52 AM
sheograth
Status: offline
Yeah ive used many of those motors in automated control projects, theyre good.
www.mangosnake.com
(in reply to AS-EE)
       Post #: 4
RE: Aqcuired a new motor!! - 8/19/2007 9:56:38 AM
Lumpmister
Status: offline
quote:
ORIGINAL: sheograth
Now that sounds fancy , but what is it???
It''s now 4:19, got a minute?
       Post #: 5
RE: Aqcuired a new motor!! - 8/19/2007 10:12:10 AM
sheograth
Status: offline
We call it "load based surface manipulation"
In laymans terms, we work on large self exciting generators, but with a twist. We're experimenting with generators that can self-adjust the field densities based on load characteristics like inductance and capacitance. Basically, generators that can sense whether the load is capacitive or inductive, and physically move the field exciter into phase with waveform produced by that load.
In REAL laymans terms: Making electrical generators used in wind turbines and hydroplants more efficient.
www.mangosnake.com
(in reply to Lumpmister)
       Post #: 6
RE: Aqcuired a new motor!! - 8/19/2007 7:16:24 PM
AS-EE
Status: offline
Here is a picture of what it looks like:
sheograth, if you have any for sale then let me know. I would be happy to buy them.
< Message edited by AS-EE -- 8/19/2007 7:18:39 PM >
       Post #: 7
RE: Aqcuired a new motor!! - 8/20/2007 2:52:02 AM
sheograth
Status: offline
Sorry, Dont have any at the moment, I'll let you know if I come into some, it does happen from time to time.
www.mangosnake.com
(in reply to AS-EE)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU3
