Charging multiple receiver packs simultaneously
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Charging multiple receiver packs simultaneously
Page: [1]
Login
Charging multiple receiver packs simultaneously - 8/19/2007 8:20:04 PM
AIRPLANENUTS
Status: offline
Guys, I read somewhere recently that if you have two battery packs plugged into the same receiver, you cannot charge the packs simultaneously. Something about the receiver creating a common ground, I think - but not sure. I'm making new packs now, and I'm assuming I need to have a pair of leads for each battery, one lead for the switch and the other lead for charging, thereby bypassing the switch in order to charge the battery. This makes sense to me, but if I'm going about it the wrong way, please let me know.
Rick
_____________________________
"Futaba gets it right the first time."
       Post #: 1
RE: Charging multiple receiver packs simultaneously - 8/19/2007 8:25:58 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: AIRPLANENUTS
Rick
If the packs have their own switches and charge jacks you can charge both at once with some chargers, there are others that do not have a common ground where it won't work.
Red S.
AMA 951 Leader Member
Disclaimer: What I have written here are my thoughts and in no manner shape or form reflect the views of RCU
(in reply to AIRPLANENUTS)
       Post #: 2
RE: Charging multiple receiver packs simultaneously - 8/19/2007 8:50:14 PM
AIRPLANENUTS
Status: offline
Thank you, Mr. Scholefield. I'll make two leads for each battery, just in case Mr. Murphy decides to visit.
(in reply to Red Scholefield)
       Post #: 3
RE: Charging multiple receiver packs simultaneously - 8/19/2007 9:27:03 PM
Red Scholefield
Status: offline
There is a schematic at the Battery Clinic web site www.rcbatteryclinic.com that may be of some help here. Look for Parallel Operation article.
Red S.
       Post #: 4
RE: Charging multiple receiver packs simultaneously - 8/19/2007 11:10:57 PM
AIRPLANENUTS
Status: offline
Thanks, Mr. Scholefield. Will do.
       Post #: 5
RE: Charging multiple receiver packs simultaneously - 8/24/2007 6:40:08 PM
Montague
Status: offline
You can also sometimes find (or you can make) a switch that also switches the ground as well as the hot lead. Most switches just do the hot lead, leaving a common ground, which is what messes with the charger.
I personally just unplug one RX battery from the RX when I charge my dual battery setup. In that plane, I can easily get to the connection between the battery and the switch, so it's easy for me to unplug. It might not be so easy for others.
Kirk Montague Adams
RCCA 560
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU3
