RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
Users viewing this topic: canavanbob, S.D.McCRAWLEY, MrMulligan
  Printable Version
Hitec HS-5965 MG Brand new untouched - RTF
Seller:  kmac425
Details:   $70.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 4/1/2008 3:10:18 AM
Charley
Status: offline
quote:
ORIGINAL: bruce88123
What do you guys expect from an intro radio anyway? They try to keep the costs down and you want it to make coffee, cook bagels and play music. Ya want more options? Wait til the higher dollar NEXT set comes out.
I have a Hitec Eclipse 7 that costs no more in standard form than the RD8000; it has both DR and Expo on the rudder with a dedicated switch. The RDS8000 transmitter is no different from the RD8000 except for the RF deck and antenna. Obviously the biggest R&D effort went into the 2.4 Gig receiver, plus field testing and time spent writing the manual.
CR
< Message edited by Charley -- 4/1/2008 3:12:50 AM >
_____________________________
Charley
ccrobins@ktc.com
(in reply to bruce88123)
       Post #: 476
RE: *Airtronics RD8000 2.4 GHz* - 4/1/2008 3:22:01 AM
Charley
Status: offline
quote:
ORIGINAL: Charley
quote:
ORIGINAL: aydin3
Dual Rate on RD8000 is no problem .
You should mix rudder --> rudder on 50% on one of the c-mix swithes.
Just set the value you want for the low rates .
Works great .
that is all that is needed..go to the C-mix you wish to use. Set it to be a mix of rudder and rudder...set the mix. What is easier?? I did that the other day and irt worked a charm....
follow the instructions in the manual (RD8000 page 46) and replace EL with RU. that is it...master is RU, Slv is RU, set each to 50 (not -50!!) and you are done. Switch the mix off and you have normal throw, on and you get 50% of the normal throw.
When the C-Mix percentages in both directions are at “0”, there will be no compensation mixing.
OK, I tried it. Works just fine. One has to get out of the Basic menu to open up the full Etc. menu, then follow the instructions beginning on page 52 of the RDS8000 manual. Now if we could get some Expo......
CR
Charley
ccrobins@ktc.com
(in reply to Charley)
       Post #: 477
RE: *Airtronics RD8000 2.4 GHz* - 4/1/2008 5:14:05 AM
aydin3
Status: offline
excellent as for expo...put it in the wish list ;*) might happen one day if we ASK nicely
       Post #: 478
RE: *Airtronics RD8000 2.4 GHz* - 4/5/2008 2:54:39 PM
speedster 1919
Status: offline
Here the deal on cell phones and our tests. We at JCRCF do not allow cell phones on flight line period. In car or back in pitts is OK. The problem is not the fact they are on or talking on them. It is when they ring only and this is with alot of brands. Some may not affect a flying TX but with all the constant changing models and brands out. We won't take a chance. Now don't chime in and tell us your wife calls you while flying and it is no problem. We have not tested the 2.4 radios for the simple fact the guy next to you might be on 72MZ. If you can't live without a phone on you for a 10 minute flight, then sell your planes and get a dog !!!!!!!!!!
Then MARRY YOUR PHONE !!!!!!!!!
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
(in reply to Lynner532)
       Post #: 479
RE: *Airtronics RD8000 2.4 GHz* - 4/6/2008 2:40:01 AM
BelAirBob
Status: offline
OK....I just ordered one from Tower. They are in stock, but it says Limited Quantities. There is a $30 off promo too. I got an extra receiver too.
I like the idea of one receiver. Plus, I have the feeling there will be a lot of Spectrums at the field this year, I like to be different and I always liked Airtonics.
bob
(in reply to speedster 1919)
       Post #: 480
RE: *Airtronics RD8000 2.4 GHz* - 4/6/2008 3:32:35 AM
hy flyr
Status: offline
Amen to that!!!
AMA #654919
Club SAITO member #523
       Post #: 481
RE: *Airtronics RD8000 2.4 GHz* - 4/8/2008 3:06:12 PM
jack1933
Status: offline
Hello All Just had Batteries America make a transmitter pak for my Rd, from Sanyo's new eneloop aa cells, 2000 mah and retain 80% charge for up to a year, and have the same low internal resistance as ni cads. So far they are working very well. Contact them if you have any questions about the cells, they also come in aaa. Will report on this thread about these cells as I use them for a while.
(in reply to hy flyr)
       Post #: 482
RE: *Airtronics RD8000 2.4 GHz* - 4/8/2008 6:00:48 PM
Four Stroker
Status: offline
I have used and tested these cells. They are the perfect transmitter pack. I only tested them for three months. They lost a small amount of charge.
(in reply to jack1933)
       Post #: 483
RE: *Airtronics RD8000 2.4 GHz* - 4/8/2008 11:39:36 PM
Harc
Status: offline
Waded through this thread yesterday and placed an order with Tower for the RDS 8000 plus and additional rcvr. Got lucky in that I'm getting $30 of the radio, however, its not in stock. Expecting them in in early April, whatever that means.
You guys really impressed me with all the comments, good, bad and indifferent. I particularly enjoyed Mike's input and that was one of the major factors for making the buy.
Used to have a couple of Airtronic radios and still have 3 new servos. So will be putting them to use shortly
C'mon Tower. Kick that boat in the stern.
Harc
(in reply to Four Stroker)
       Post #: 484
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 12:35:44 AM
MikeGreenshields
Status: offline
We have them in stock and I believe Tower has already ordered some more from us. My guess is they will be in stock very soon.
Mike
Mike Greenshields
Product Manager
(in reply to Harc)
       Post #: 485
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 12:45:12 AM
BelAirBob
Status: offline
Mike....any update on what Airtronics announced or showed at Toledo? There seems to be very little on Toledo on the web that I can find. Although I am sure everyone was burnt out after the show and traveling home.
I ordered my Airtonics Sunday. It shipped and should be here Friday or Monday
Bel Air Bob
(in reply to MikeGreenshields)
       Post #: 486
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 1:17:39 AM
2fast
Status: offline
I have plenty in stock and at a great price.
www.wingsandwheelshobbies.com
(in reply to BelAirBob)
       Post #: 487
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 2:58:55 AM
colrod12
Status: offline
first off, I would like to thank mike greenshields for his awesome support I'm getting me one!! a RD8000 not a mike
got my bid in on one as we speak/type, and for back up I got one back order as well. I've had aRD6000super for 4 years now and love it! always wanted a RD8000 and now is the time!!
I was pondering on a JR9303 since I got a 6102 and like that as well but the airtronics will do just fine thank you. can't wait
Raptors30/30-70/70.Hurricane50.G4-Trexer/HDE-trexer.X400/X400Eccpm.hoping all to be on my Airtronics,2.4mgz-RDS8000,soon.
(in reply to 2fast)
       Post #: 488
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 3:08:01 AM
MikeGreenshields
Status: offline
I just posted some stuff on my blog
mikegoesflying.wordpress.com
Even has a pic of the nice Toledo show spokesmodel with the RDS8000
Mike
Mike Greenshields
Product Manager
(in reply to colrod12)
       Post #: 489
RE: *Airtronics RD8000 2.4 GHz* - 4/9/2008 3:25:46 AM
colrod12
Status: offline
mike just real quick,
will there be any problems with a buddy cable on the new 8000?, would it be possible to hook up a RD6000super to the new RD8000 to use as a buddy box? or do the band diffrences prevent that?
