RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
  Printable Version
Hitec HS-5965 MG Brand new untouched - RTF
Seller:  kmac425
Details:   $70.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  23 24 [25] 26 27 28 29 30 31 32   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 4/29/2008 6:04:36 PM
alex_bong
Status: offline
Tested RDS8000 on phoenix sim with diy adaptor, can't work, don't know why? but it's work with my Futaba 6EXH.
(in reply to alex_bong)
       Post #: 601
RE: *Airtronics RD8000 2.4 GHz* - 4/29/2008 11:18:42 PM
bigedmustafa
Status: offline
quote:
ORIGINAL: Oldbob
Four Stroker
Well I guess some of my Futaba equipment is over 15 years old. In Dog years that’s 105 years old and still working fine. I just didn’t want to change servos that are working fine just to try the new radio. I still have some S138, S148, S9202 and S3002. Futaba makes good servo but I stopped buying Futaba servos because they are too expensive. Tower servos cost less and work every bit as good and I just noticed that they require NO modification to fit into the Airtronics Rx.
I didn’t get a chance to fly today but maybe tomorrow will be a better day. I’m anxious to try this new radio.
OldBob
You will find that Hobbico and Tower Hobbies servos are very "High Tech," if you get my meaning. All three brands will plug right in to the Airtronics 92824 receiver. I was actually testing mine out with a Vigor VS-2 servo that I bought from Hobby City. Pretty much any currently manufactured servo will plug right in except Futaba.
_____________________________
To a tree, balsa wood and MonoKote taste just like chicken!
(in reply to Oldbob)
       Post #: 602
RE: *Airtronics RD8000 2.4 GHz* - 4/30/2008 12:24:02 AM
Oldbob
Status: offline
Can someone help me?
It’s been a long time since I sent in a warranty card. I find all kinds of numbers on my new radio but NO serial number. The warranty card requires a serial number, where do I find it? I’m sure I won’t need to use the warranty, but just in case!
OldBob
(in reply to bigedmustafa)
       Post #: 603
RE: *Airtronics RD8000 2.4 GHz* - 4/30/2008 1:34:21 AM
Waco
Status: offline
take the battery out and its behind the battery.
       Post #: 604
RE: *Airtronics RD8000 2.4 GHz* - 4/30/2008 4:26:46 AM
Oldbob
Status: offline
Got it, thanks
(in reply to Waco)
       Post #: 605
RE: *Airtronics RD8000 2.4 GHz* - 4/30/2008 11:55:12 AM
Zippi
Status: offline
I finally got my radio in after UPS had it held hostage for 8 days. Upon opening the box I to found the receiver, switch, and the charger were not wrapped and had been just falling around. Other than that it looks and feels really nice. It's on charge and awaiting it's first mission.
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 606
RE: *Airtronics RD8000 2.4 GHz* - 4/30/2008 11:16:34 PM
Zippi
Status: offline
I got a chance to see how the programing and binding process was today and I have a question. After you go through the binding process it says in the manual that the light on the receiver will stay solid. Mine does not, it flickers all the time after binding but everything seems to work ok. Is this normal for the receiver light to flicker and not be a solid blue?
(in reply to Zippi)
       Post #: 607
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 12:56:02 AM
BelAirBob
Status: offline
Mine does what Zippi states also. ....flashes fast instead of steady light. Everything seems to work OK though.
bob
(in reply to Zippi)
       Post #: 608
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:10:46 AM
bigedmustafa
Status: offline
Umm, I think that's a problem fellas. I'm at work and don't have my manual handy. When I bound my receiver, it stayed lit with a steady blue LED.
(in reply to BelAirBob)
       Post #: 609
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:17:09 AM
rlmcnii
Status: offline
RD 8000 2.4 Users,
Anybody here find anything bad about these radios???
       Post #: 610
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:29:25 AM
RCKen
Status: offline
My biggest complaints about the radio was the 3 digit display when naming a model, the small transmitter battery (by today's standards), and the lack of expo and dual rate on rudder. IMHO these are all minor issues. As far as the radio itself, it's rock solid and will be making lots of trips to the field with me.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to rlmcnii)
       Post #: 611
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:39:44 AM
bigedmustafa
Status: offline
quote:
ORIGINAL: rlmcnii
RD 8000 2.4 Users,
As a Futaba 7C owner for the last several years, I'm expecting a bit of learning curve with the RDS8000's programming interface. I don't think programming the radio will be difficult, I just need to learn Airtronics' abbreviations for everything.
At the same time, there is an elegant simplicity to the RDS8000 and I think I may end up liking it better than my 7C once I get the hang of it. The RDS8000 strikes me as an "everything you need and nothing you don't" kind of product.
I helped somebody program their Airtronics radio out at the field one time and I'd never seen one before. The radio owner had never owned a computer radio before, however, and we were able to get his trainer dialed in and trimmed out quickly and easily. There seems to be a consistency to all Airtronics radios with regard to programming, that doesn't always seem to be the case with other brands.
       Post #: 612
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:42:54 AM
RCKen
Status: offline
Ed,
I think that the Airtronics programming is very good. But I've been used to it. It's the same programming that was used in both the RD 6000 and the RD 8000. Yes, you are right in Airtronics does stay consistant with their programming.
Ken
       Post #: 613
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:47:22 AM
MikeGreenshields
Status: offline
A slight flash/blink of the blue light is really not an issue. Changing the position of the antennas in relationship to each other as you stand there will change that blinking light. If there's no light, that's a problem! But a little bit of a blink is not an issue.
Mike
Mike Greenshields
Product Manager
       Post #: 614
RE: *Airtronics RD8000 2.4 GHz* - 5/1/2008 1:49:58 AM
RCKen
Status: offline
Hey Mike!!!! It was great to finally meet you in person in Toledo this year!!!! Thanks for visiting with the RCU crew about the great Airtronics products. But now you have me drooling for that 10 channel radio!!!!
Ken
(in reply to MikeGreenshields)
