RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
Users viewing this topic: bigedmustafa
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  24 25 [26] 27 28 29 30 31 32 33   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 5/5/2008 12:18:46 AM
RCKen
Status: offline
I just turn the radio off, and then turn it back on to ensure that it's back to normal mode.
Ken
_____________________________
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner's, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to Zippi)
       Post #: 626
RE: *Airtronics RD8000 2.4 GHz* - 5/5/2008 12:41:51 AM
Zippi
Status: offline
RCKen,
Thanks for the help. That was just to easy. For those of you reading this thread and thinking of getting this radio there is nothing wrong with the radio at all. This is what you call and I hate to say it, "Operator Error".
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to RCKen)
       Post #: 627
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 10:46:10 AM
stratusman
Status: offline
hi Mike!!
I have already installed the rds receiver on my stratus..this is a photo...
it's a good installation..??
[URL=http://img394.imageshack.us/my.php?image=rdszm2.jpg] [/URL]
regards , Andrea
(in reply to Zippi)
       Post #: 628
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 1:34:56 PM
RCKen
Status: offline
stratusman,
That's perfect. As long as you have the two antenna elements placed 90° to each other you won't have anything to worry about.
Ken
(in reply to stratusman)
       Post #: 629
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 1:42:14 PM
stratusman
Status: offline
thank you very much for the reply..[)]
(in reply to RCKen)
       Post #: 630
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 2:35:11 PM
zertsman
Status: offline
that's a great idea.. i'll have to try that. i bet it was fun fishing that up the T
       Post #: 631
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 4:26:56 PM
MikeGreenshields
Status: offline
The mount you made is perfect. Very clever!
Mike
Mike Greenshields
Product Manager
(in reply to zertsman)
       Post #: 632
RE: *Airtronics RD8000 2.4 GHz* - 5/7/2008 5:59:46 PM
stratusman
Status: offline
work finished
[img=http://img380.imageshack.us/img380/4545/cimg6963fe1.th.jpg]
the "T"..with the K&S filter support.
(in reply to MikeGreenshields)
       Post #: 633
RE: *Airtronics RD8000 2.4 GHz* - 5/8/2008 3:17:44 AM
Jeff Pfeifer
Status: offline
Here are a few install pics of mine all with the antennas 90degrees to each other. The three models shown are a Q500 Pylon Racer, an Align T-Rex 600 Nitro, and an Align T-Rex 450. I use R/C Car antenna tubing to route the antennas and with a little heat the antenna tubing is moldable to achieve the 90degree antenna orientation. Enjoy!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Airtronics,Align,CSM,Castle Creations,FlightPower
FOX Fuel,Maverick Hobbys,V-Blades
       Post #: 634
RE: *Airtronics RD8000 2.4 GHz* - 5/11/2008 7:39:07 PM
clarc
Status: offline
can anybody tell me if it`s ok to run (2) 6 volt battery packs (nickel metal) and (2) switches without regulators on this new airtronic receiver. I have a 30% sd-yak with a DL-50. I will be using hitec servos, 5955tg on rudder, and 5985 on all other control surfaces. I have been using both the rd6000 and rd8000 for several years. Thanks for any info or suggestions!
(in reply to Jeff Pfeifer)
       Post #: 635
RE: *Airtronics RD8000 2.4 GHz* - 5/11/2008 7:41:52 PM
RCKen
Status: offline
Absolutely you can. It will run just like the older receivers you are used to using.
Ken
(in reply to clarc)
       Post #: 636
RE: *Airtronics RD8000 2.4 GHz* - 5/11/2008 9:27:19 PM
clarc
Status: offline
Ken, Thank you very much!
(in reply to RCKen)
       Post #: 637
RE: *Airtronics RD8000 2.4 GHz* - 5/12/2008 11:19:13 PM
zertsman
Status: offline
i finally got to use mine.. after flying, i stuffed it all in the back of my truck and drove to the LHS which was prolly a 15min trip or so. when i got there to take my plane and TX in the shop, it was beeping and said something about power in the display. i thought i had ran the batt down in what i thought was a short time, but i have since flown again on the same charge and all is fine with the charge left in the battery. does this TX have a warning that will go off after a certain amount of time not touching the TX? can't find any mention in the manual of an alarm telling the bonehead he forgot to turn his TX off. but it would be a nice feature.
(in reply to clarc)
       Post #: 638
RE: *Airtronics RD8000 2.4 GHz* - 5/12/2008 11:42:41 PM
MikeGreenshields
Status: offline
after 15 minutes of the tx on with no "input".. no stick movement, no trim movement, etc... it beeps to tell you the radio was left on.
Mike
Mike Greenshields
Product Manager
       Post #: 639
