Capt. Crackup
GA, USA Status: offline
Hey All, I have not posted in this forum in a while. I've been busy flying with my RDS 8000. I am using the RDS in 3 airplanes. A Dual Ace 46, a Tiger 60, and a Senior Telemaster. As I said in earlier posts, I replaced a Futaba 6XAS with the RDS, and I can say that I LOVE MY RDS!!!! As for twin engine operation, I tried to use different channels on my Dual Ace. I could never quite get the engines matched. So I just went back to doing it the old and reliable way of using a y harness. It takes much ground time and many flights to get every thing set but once it's there, it works great. As for the other mixes, they appear to work great. Specifically I use the Flaperon mix, Elevator to flap mix, Aileron Differential, Dual Elevator and of course I use throttle cut. All work great. The dual elevator mode makes dual servos a snap. For those who fly Multi engine birds or HEAVY Warbirds that require you to use the throttles to control you rate of descent during final will probably frown when you discover that the throttle channel does not have expo. However, by moving the CENTER function up (+%) you can soften the bottom response for a expo feel. Seems to work good. The program navigation for the RDS is definitely different than that of Futaba. But it is easy to get use to, and once you start using it it makes since. One example, ( but there are many) is on the Futaba, dual aileron servos use ch 1 and 6. You use the both channels ATV to set differential. On the RDS you use ch 2 & 6. to program diff, you go to channel 2 under AL-DIF and you can adjust from -100 to +100%. This effects both channels. If you think about it, ,,,,,,,,makes since, huh? This is only one example. There are a few. All in All this is a great radio and I HIGHLY recommend it. Skip D
< Message edited by Capt. Crackup -- 5/30/2008 10:10:18 PM >
_____________________________
There's only one thing cooler than Radio Controlled Aircraft,,,,,,,,,,that's the guys that fly em!! Capt. Crackup
