RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
Users viewing this topic: TMooreATX
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  28 29 [30] 31 32 33 34 35 36 37   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 6/6/2008 2:24:43 PM
zertsman
Status: offline
i just set up my spa3d with flaperons.. the flaps were preset.. i kept wondering why the ailerons were at strange places. then in remembered the above posts.. i had to change the flap values to 0% and all is well. i couldn't figure out how to deactivate the switch without setting the values to 0. but it worked.
(in reply to Clay Walters)
       Post #: 726
RE: *Airtronics RD8000 2.4 GHz* - 6/8/2008 1:31:22 AM
Skyflying1
Status: offline
test
(in reply to zertsman)
       Post #: 727
RE: *Airtronics RD8000 2.4 GHz* - 6/8/2008 1:54:16 AM
Oldbob
Status: offline
Skyflying1, your test worked, how can we help you?
OldBob
(in reply to Skyflying1)
       Post #: 728
RE: *Airtronics RD8000 2.4 GHz* - 6/8/2008 3:47:47 AM
rlmcnii
Status: offline
RCKen,
Very comprehensive review. It looks as if it must have been a good deal of work to prepare. Thanks! This looks like a very nice radio and it will provide my entry to 2.4.
All,
Does anyone out there miss three-position switches for channels five and up?? I may have mis read the review but it seems as if the assignable, and pre-assigned, toggle switches are all two-position.
This is probably a very minor concern and will probably be addressed with the 10-channel TX. This radio, as presently configured, seems to be a gift to the R/C community. Thank you, Airtronics!
(in reply to RCKen)
       Post #: 729
RE: *Airtronics RD8000 2.4 GHz* - 6/8/2008 8:27:01 PM
MikeGreenshields
Status: offline
The flap switch is 3 position, the others are all 2.
_____________________________
Mike Greenshields
Product Manager
(in reply to rlmcnii)
       Post #: 730
RE: *Airtronics RD8000 2.4 GHz* - 6/8/2008 10:39:01 PM
rlmcnii
Status: offline
MG,
Thanks, I must have missed that.
(in reply to MikeGreenshields)
       Post #: 731
RE: *Airtronics RD8000 2.4 GHz* - 6/11/2008 3:47:58 AM
bigedmustafa
Status: offline
I was wondering if there might be any updates regarding the 6-channel parkflyer receiver yet?
To a tree, balsa wood and MonoKote taste just like chicken!
       Post #: 732
RE: *Airtronics RD8000 2.4 GHz* - 6/11/2008 5:59:19 PM
MikeGreenshields
Status: offline
It is being worked on and is planned for release later this year
Mike Greenshields
Product Manager
(in reply to bigedmustafa)
       Post #: 733
RE: *Airtronics RD8000 2.4 GHz* - 6/12/2008 12:30:16 AM
djlyon
Status: offline
For several years I've been primarily using Airtronics radios beginning with the Module, a couple of Spectrums, Radiant, RD6000, RD6000S and RDSS8000 . I've been very happy with all of them except the Radiant. With it I had functionality issues. I never had a failure with any of them except the new RDSS8000. It seems it just quit transmitting after about 30 flights. Tried rebinding and different receivers, no help. A different transmitter worked fine with the receivers. I was just about to fly a pylon racer on our practice course when it quit. We do a last second pre-launch check that caught it. Took the system back to Hobby People and they gave me a new one. It works great and guides my pylon racers.
A couple of things I should note that are not biggies in my mind. Like some racers I like my sticks springs very tight when fly pylon racers. The new radios use a metal plate to hold the gimbal locators (maybe not what you call them) in place. The old radios use plastic. When the aileron spring is tightened to near max the spring rubs on the plate. This gives you a clickity click click when you move the aileron stick. The locator it self has a relief cut out for this but the plate does not. I fixed it by filing a relief in the plate.
My second transmitter doesn't chime when I activate the rudder trim. All other trims chime just fine. again no biggy.
Denis
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
       Post #: 734
RE: *Airtronics RD8000 2.4 GHz* - 6/12/2008 6:37:00 PM
jabowil-RCU
Status: offline
Is there a release date yet for the Stylus 2.4 Ghz module?
thanks,
Jerry
       Post #: 735
RE: *Airtronics RD8000 2.4 GHz* - 6/15/2008 12:48:56 AM
TLH101
Status: offline
quote:
ORIGINAL: jabowil-RCU
thanks,
Jerry
+1
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to jabowil-RCU)
       Post #: 736
RE: *Airtronics RD8000 2.4 GHz* - 6/15/2008 1:25:31 AM
MikeGreenshields
Status: offline
Stylus Module is in final design stages. We'll test it late this summer. It is our goal to have it out by the end of the year.
Mike
Mike Greenshields
Product Manager
(in reply to TLH101)
       Post #: 737
RE: *Airtronics RD8000 2.4 GHz* - 6/17/2008 12:22:50 AM
blkbird68
Status: offline
quote:
ORIGINAL: MikeGreenshields
Mike
Need any beta testers???
       Post #: 738
RE: *Airtronics RD8000 2.4 GHz* - 6/20/2008 2:11:47 PM
jetpilotrich
Status: offline
Mike,
I have a RDS8000. I am confused about the what the resolution is? I have been using a old futaba 9 channel PCM 1024. Some of the higher end ($) futaba radios advertise a real time response (faster) of 2048 resolution. Where does the RDS 8000 fit in to this. I guess I am confused about what the difference is between 2.4 and resolution or are they one in the same?
Here are some pics of the RDS8000 in action on my Cermark F-16 with a JETT 90L.
Rich
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
