MaineBear
Joined: 4/16/2002 From: PRIVATE, VA, USA Status: offline
Hi Zippi! Thanks for the pics. Your fuel line fix looks good and should last until Airtronics corrects their design and supplies you with a new one. Also, good to read Mike G will be following up with Airtronics. Mike G.: Would you get back with everyone on this as to what Airtronics plans to/will do - and when? For everyone's peace of mind I'm sure we'd all like to know what Airtronics action is taking. Thanks... Your pics tend to confirm my thoughts that perhaps one of the reasons the RDS8000 is so price competitive is because Airtronics peobably used existing RD8000 tooling for their RDS8000 case design thereby eliminating new tooling (mold) costs. Makes sense; many companies frequently take this approach to save costs - but it doesn't always go smoothly. What you found out, though - and what others might, too - is that when the RD8000's collapsible metal antenna was removed and the older case design is used, only the thin plastic molded wall (around it) is left, and this - by itself - is not strong enough to fully support the 2.4 wire antenna cover extending above the case, which, when being assembled, or when being handled during normal use, the thin wall plastic would be subject to breakage. Anyway, good to read you are back in business. One question, though: would you recommend everyone place something solid and supportive - like fuel line, as you did - around their antenna wire to fill the space that space that now exists (between the antenna wire and the plastic) ? Sounds like it might be a good move. Thanks again, Zippi, for bringing this problem to everyone's attention... Dick
