CCFPILOT
CA, USA Status: offline
Captn Crash I hope soon you will be able to change your name. I'm not sure of your description of antenna placement, but if you mean running one antenna on one side of the fuselage forward, and on the other side of the fuselage aft, that would be 180 degrees, not 90. If on one side the antenna was "up" (vertical), that would be 90 degrees. However; even if both antennas were on the same side of the fuselage with one horizontal, and one vertical would also be 90 degrees. Ethan
