RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
Users viewing this topic: canavanbob, S.D.McCRAWLEY, MrMulligan
  Printable Version
JR 12X Transmitter only
Seller:  BAGOSTIX
Details:   $1,300.00   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  37 38 [39] 40 41 42 43 44 45 46   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 8/31/2008 2:35:15 PM
scootter
Status: offline
has anyone had a problem with losing info or other problems if transmitter switch is left on and battery goes completely dead?
(in reply to bigedmustafa)
       Post #: 951
RE: *Airtronics RD8000 2.4 GHz* - 8/31/2008 5:58:23 PM
blvdbuzzard
Status: offline
I got my first flight with my RDS8000 yesterday. It was so uneventful. I did have an issue with the Tx though. The two flights I got in, I tried to extend the antenna both times. It is going to take a little time to get used to the short antenna. I kept looking down to see if the antenna was extended. Other then ME having trouble, the RDS8000 was flawless. I just need to get 9 more Rx's for this Tx.
I have pulled the battery out to charge on my Tritton II charger and have not lost any data. Not sure if that is the same as having it run down the voltage on the battery.
Dru.
(in reply to scootter)
       Post #: 952
RE: *Airtronics RD8000 2.4 GHz* - 9/1/2008 3:04:05 AM
GotSky
Status: offline
Mike Greenshields
Could you please PM your contact info, my radio went dead today. It went into the no transmit a signal deal on power up. It worked fine on the 1st flight of the day then stopped transmitting signal on the next power up cycle. Mine is one of four Rd8000's at our field and 3 of them have had this issue so far. The 2 others I know you have been informed about via this chat board (member: djlyon). Please get back to me as soon as you can as I have switched everything over to this 2.4 radio and can not fly until this is resolved. If you look back near the start of this tread you will remember that I was one of the 1st people to get this radio (post pictures) and make the switch - we also talked at the AMA show.
Thank you for your prompt attention to this matter
John
jwmclean@dslextreme.com
< Message edited by GotSky -- 9/1/2008 3:08:11 AM >
(in reply to blvdbuzzard)
       Post #: 953
RE: *Airtronics RD8000 2.4 GHz* - 9/1/2008 3:58:39 AM
gaRCfield
Status: online
quote:
ORIGINAL: bigedmustafa
Have you checked out page 12 of the manual for the RDS8000, cappaj1? It gives detailed instructions for adjusting the stick tension springs to tune your radio to your liking. Have you already tried this and you're still not happy with maximum tension, or did you not know that the spring tension is adjustable?
The question actually came from me - I tried tightening the screws that adjust the spring tension, and I started getting a 'clicking' noise when I moved the sticks so had to lighten up on the tension a bit. I've been flying Futaba and JR until this radio, and all the radios I've used have much tighter spring tension. I'd love to replace the spring or do something to increase the tension further.
_____________________________
..this hobby is doing weird things to me...
       Post #: 954
RE: *Airtronics RD8000 2.4 GHz* - 9/1/2008 7:32:57 PM
CCFPILOT
Status: offline
Error in RDS8000 operating manual
Mike Greenshields:
PAGE 12;
"TRANSMITTER STICK TENSION ADJUSTMENT
-remove the back of the transmitter case. First remove the ANTENNA and NiCd battery-."
The Antenna does not need to be removed and should not be removed. This instructions pertains to the RD8000 72MHz antenna.
(in reply to gaRCfield)
       Post #: 955
RE: *Airtronics RD8000 2.4 GHz* - 9/1/2008 9:24:09 PM
djlyon
Status: offline
GaRCFIELD
See my post 734 on spring problem and fix I applied
Denis
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
       Post #: 956
RE: *Airtronics RD8000 2.4 GHz* - 9/1/2008 10:03:26 PM
gaRCfield
Status: online
Ok, thanks Dennis.
(in reply to djlyon)
       Post #: 957
RE: *Airtronics RD8000 2.4 GHz* - 9/2/2008 12:27:33 AM
MikeGreenshields
Status: offline
GOTSKY I sent you an email directly. You can pm me here at RCU or email me directly
Mike
Mike Greenshields
Product Manager
       Post #: 958
RE: *Airtronics RD8000 2.4 GHz* - 9/2/2008 4:15:42 PM
gaRCfield
Status: online
Liking the radio so far. Looking to get the spikes for the thumb grips, and make a relief in the spring tension plate - I think I'll be really happy with better grip and stiffer springs.
Nice one from Airtronics
(in reply to MikeGreenshields)
       Post #: 959
RE: *Airtronics RD8000 2.4 GHz* - 9/2/2008 5:28:15 PM
CCFPILOT
Status: offline
Mike Greenshields:
I think an important improvement on your new 10 channel radio would be an option to "disable the TRANER SWITCH" on the transmitter. I just crashed an airplane because while retracting the gear I accidently brushed the TRAINER switch, so I for one would like to have the option to disable that switch. I don't know if other radios have this option or not, since I have been using only Airtronics for the past 25 or so years.
Ethan Marsh
       Post #: 960
RE: *Airtronics RD8000 2.4 GHz* - 9/2/2008 6:27:24 PM
RCGeckoman
Status: offline
Just had my first really good day wioth the new RDS..I love it!! Better than any radio I have had over the years Ihave been in the hobby. It was flawless, just wish I coudl say the same of the pilot :*) greased my first landing on a new plane, then opened up for another go round and opps...ran ouf or electric so stalled and pulled the undercarriage off...ahw well..the model timer will help next time with that
Looking forwward to seeing what changes the 10 channel will bring as there are a number of things I would love to have included
Dave L.
go visit WWW.FLYFORTOTS.COM See what North Carolina pilots are raving about!! only 18 more days until the best weekend of flying in NC!! ALL pilots, ALL models accepted as long as current AMA member with proof! come join us in Youngsville NC for a weekend youw il never forget! and help some really deserving children into the bargain!!
(in reply to CCFPILOT)
       Post #: 961
RE: *Airtronics RD8000 2.4 GHz* - 9/2/2008 7:16:49 PM
bruce88123
Status: offline
quote:
ORIGINAL: CCFPILOT
Mike Greenshields:
Ethan Marsh
Yes, some other brands/models do require/allow the "Trainer Mode" to be enabled/disabled or allow you to assign functions to switches so you can choose which switch does what. This may become a feature on the 10 channel. I'm sure they were concentrating on keeping costs down on this initial offering.
3-D is for Monster Movies
       Post #: 962
RE: *Airtronics RD8000 2.4 GHz* - 9/4/2008 12:45:26 AM
GotSky
Status: offline
Mike
The radio was sent out today via Priority Mail. You should have it tomorrow or Friday.
(in reply to bruce88123)
       Post #: 963
RE: *Airtronics RD8000 2.4 GHz* - 9/4/2008 12:49:55 AM
MikeGreenshields
Status: offline
You're close, I'll get it quickly! Thank you for sending it in.
Mike
Mike Greenshields
Product Manager
(in reply to GotSky)
       Post #: 964
RE: *Airtronics RD8000 2.4 GHz* - 9/5/2008 1:23:39 AM
GotSky
Status: offline
Mike,
Hope it made it to you today. I just found out you should also be getting one from my buddy as well. (Last name Lyon). His should have been there today I'm not sure if he put it attention to you or not however. Hey when you send it back to me throw a couple extra receivers in there would ya.. I won't tell any one.. HAHAHA
