MikeGreenshields
CA, USA Status: offline
I sent you an email about it. But clearly it's not "buggy", it has suffered some sort of computer problem. Just like any computer there's programming in it and if something goes wrong somewhere else in the radio, it can cause the computer problems. Essentially the programming is corrupted. So, if they initially messed up a wire or pot or something or one failed prematurely that resulted in a short on the pot or PC board, that's a wire that essentially is connected directly to the computer. Shorting anything on a pc board that is connected to a computer is typically "bad" (which is why you need to be really careful and make sure the battery is disconnected if you ever need to pop the case open.) Anyway, it does seem that this has happened and if so, the only safe solution, as you said, is to replace the radio. I will be looking at it with Minh when it gets back. Mike
< Message edited by MikeGreenshields -- 9/11/2008 1:00:02 AM >
_____________________________
Mike Greenshields Product Manager
