RE: *Airtronics RD8000 2.4 GHz*
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: *Airtronics RD8000 2.4 GHz*
Page: <<   < prev  40 41 42 43 [44] 45 46 47 48 49   next >   >>
Login
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 6:01:51 PM
zertsman
Status: offline
do you mean the physical distance the stick moves or the servo arm?
i can't say i've noticed on mine.. i'll have to check.
(in reply to turboayuso)
       Post #: 1076
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 6:23:51 PM
turboayuso
Status: offline
quote:
ORIGINAL: zertsman
Yep, the physical distance the left stick moves in vertical way.
(in reply to zertsman)
       Post #: 1077
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 8:39:03 PM
mrbigg
Status: offline
quote:
ORIGINAL: RCKen
Yes, it is only the rudder channel that doesn't have dual rates or expo. But, it is possible to mix the rudder with one of the aux channels to give it dual rates if needed.
Ken
How are you doing this?
_____________________________
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
(in reply to RCKen)
       Post #: 1078
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 8:48:03 PM
RCKen
Status: offline
quote:
ORIGINAL: mrbigg
quote:
ORIGINAL: RCKen
Ken
I'll have to see if I can find it again. Somewhere back in this thread it was posted how to do this. I'll look for it and see if can find it.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to mrbigg)
       Post #: 1079
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 9:36:04 PM
djlyon
Status: offline
Select aux1 or 2 as your rudder dual rate switch. Example: Select etc. Page down until you see (MAS 1). Select RU. Page down. You see SLV 1. Select RU. Page down. You see 0%. Select +50 with the rudder to the right and +50% with the rudder to the left. Now turn your receiver on and move the rudder to full and while holding it there move the aux 1 switch up and then down.Watch what happens to the rudder. You'll get the idea then and can set things up the way you want.
Be careful to check every thing when you do this. My son accidentally coupled down elevator to up throttle while setting up elevator to rudder. The result was total loss of the plane.
I fixed my post 903 issue this way.
Denis
< Message edited by djlyon -- 9/26/2008 9:48:49 PM >
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
(in reply to RCKen)
       Post #: 1080
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 10:01:03 PM
RCKen
Status: offline
Denis,
Thanks for covering me. I haven't had a chance to go back through and look for the post.
Ken
(in reply to djlyon)
       Post #: 1081
RE: *Airtronics RD8000 2.4 GHz* - 9/26/2008 11:25:59 PM
RJConnet
Status: offline
Turbo,
Just checked and all of my Transmitters are that way, Futaba, Airtronics, and Hitec. Less throttle stick travel than elevator, aileron, and rudder sticks.........RJ
       Post #: 1082
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 12:08:03 AM
mrbigg
Status: offline
Thanks guys. Great idea.
(in reply to RJConnet)
       Post #: 1083
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 12:11:14 AM
turboayuso
Status: offline
quote:
ORIGINAL: RJConnet
Turbo,
Thank you very much, RJ.
Apart from this Airtronics I only own a Multiplex one, which has complete travel for both sticks, so I wasn't sure if this was right (suspected it, as the radio didn't show the TH-Hi warning when turning on with throttle stick at lower position).
Roman.
       Post #: 1084
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 3:04:02 AM
Planeclothes
Status: offline
quote:
ORIGINAL: RJConnet
Turbo,
True for Futaba and Airtronics, but my Hitec Optic 6 has equal stick travel for elevator and throttle.
< Message edited by Planeclothes -- 9/27/2008 3:06:04 AM >
I'm only in it for the money...
       Post #: 1085
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 4:05:21 AM
djlyon
Status: offline
Yup normal for all Airtronics, Futaba and Cirrus transmitters I have seen. Hitec up and down stick travel is the same for both right and left stick on my Eclipse. But you want to know what? I never even noticed until you brought it up.
Denis
< Message edited by djlyon -- 9/27/2008 6:44:26 AM >
       Post #: 1086
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 4:58:54 AM
Planeclothes
Status: offline
Me neither, I had to go and check all my radios.
       Post #: 1087
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 5:23:34 AM
Shubova
Status: offline
Thanks, your post on rudder D/R is quit interesting. I'm going to try it.
Does anyone know of a way get exponential on the rudder? Just out of curiosity does anyone know way they have been leaving it out on all their radios? It sure would a nice thing to have.
Shubova
       Post #: 1088
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 2:58:35 PM
mrbigg
Status: offline
quote:
ORIGINAL: Shubova
Shubova
The reason we were told a while back, (not in this thread) was that there was no room on the circuit board.
You can get Expo and Dual Rate on the rudder by using the Heli program with your plane. I have done this on my .40 sized profile Ultimate. I just copied it from the airplane program. Worked great. You do lose the dual elevator function and flaperons though. I like them two features for my giant scale models so I stick with the airplane programming. I've also become really smooth on the rudder with no expo.
(in reply to Shubova)
       Post #: 1089
RE: *Airtronics RD8000 2.4 GHz* - 9/27/2008 8:07:14 PM
BelAirBob
Status: offline
Does anyone out there trickle charge their RDS8000 after charging? I charge over night and use the Lil Trickler. I recently noticed that the voltage is dropping to below 9.6 on tricke if it has not been charged in a week. I could leave my JR;s and old Airtronic on trickle for months after a full charge and they were ready to go. Any ideas? I just noticed this
Also, it looks like the 2009 Tower catalog has wiped all Airtronics stuff from the pages.....? Not that it matters I guess, but most hobby shop
