rlmcnii
Joined: 7/3/2005 From: Pocomoke City, MD, USA Status: offline
rheauljj, I have built and flown two Bruce Tharpe Ventures, both powered by Saito.82s. It is a very nice match for the airframe and is actually several ounces (6, I think) lighter than the OS two-stroke around which the airplane was apparently designed. In mine the batteries had to be mounted in front of the servos for proper balance. The Saito .82 will not give the Venture unlimited vertical, but is more than sufficiently powerful for sport flying. So far, my flying of the Venture is limited by me and not the engine. There seem to be many reports of how badly the .82 vibrates. I have not found that to be true with either of the two I have operated. As BLW states in a previous post, Saitos will shake when improperly tuned. The solution is to tune them properly. It is not difficult to do, but it needs to be done. One very nice property of the Saitos is their fuel efficiency. With the 16 ounce tank in the Venture and a well tuned .82 you will easily get two 12 or 14 minute flights out of the tank and land with a nice reserve. Fuel burn is just not an issue with that engine. Mine are run on 15% Omega (the consensus seems to favor a bit of castor in the fuel) and fly with a 13x6 Pro Zinger. Plastic props may work better, but I just like wood. A 14 inch prop is a little too large for a Venture...not enough ground clearance. A lot of people fly with fuel of a higher nitro content. That may give you some more power. Might try that someday! Saitos sound a lot different than 2-strokes. Your preference is your preference. Many people at the field where I fly have commented on what a pretty plane the Venture is and nobody could believe it was not an ARF. There is another guy at our field building one now and at least one fellow has offered to buy mine. If you are neither a 3-D disciple, nor a contest-winning-level pattern flyer, you will probably be very pleased with your Venture. If you are either of these and just want a nice sport plane, you will also probably be pleased. Hope yours goes well, regardless of your choice of engine. But, it needs a Saito!
