richbran
Joined: 11/23/2003 From: Ederveen, NETHERLANDS Status: offline
The Std 1250 only suffice for about 3 succesful starts/flights, after that it is unwise to fly w/o recharging (no problem for fast charge with NiCad) I have replaced them initially with NiMh, but these (2300 penlight size) proved to have an horrendous discharge rate when not in use, easily getting flat in two weeks.(Yes, disconnected from the ECU....) The other problem I found was that NiMhs cannot stand peak loads as opposed to NC(starting costs LOTS of energy, I guess with kerostart even more...), the voltage dropped therefore awfully resulting a many false starts (in wintertime in Europe...) Now I replaced them with more or less Standard Lipos 2C/2100. I did not test it, but a friend of mine claims 10 starts/flights on one charge. Voltage drops way less during starting as NiMh. Drawbacks of Lipo should be known: At least 2-3 times more expensive as NC, dedicated charger with balancer needed, careful handling. Possibly gone in two-three years, carefully handled NC can get 7-8 years I have found out. I have about one hundred batteries of which I keep a good track record. As You are a beginner and likely not to fly a lot in the beginning (or charge when Your adrenaline level has to be lowered between flights...), stick to the standard NC, a great battery. Later, and if You are looking to save every gram on your plane, Lipo would come as the best alternative.
_____________________________
Regards, Richard
