balancing biplane
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> balancing biplane
Page: [1]
Login
balancing biplane - 8/20/2007 3:24:45 PM
CHARGER0_6
Status: offline
i have a cox ultimate biplane with a 52 saito 4s. manufacture says cg to lower wing. i dont seem to get it balance. move battery and added lead still nogo. seems to balance on upper wing right on. any ideas. are biplanes balanced on upper or lower wing
       Post #: 1
RE: balancing biplane - 8/20/2007 6:26:19 PM
gboulton
Status: offline
I've balnced every one I've owned on the top wing....but then, the plans and/or instructions specified the CG on the top wing. If yours specify the CG on the bottom wing, I'd rather strongly suggest you follow that suggestions. Bipes...especially aerobatic ones...do NOT like flying tail heavy. At all.
_____________________________
The free man will ask neither what his country can do for him nor what he can do for his country. - Milton Friedman
(in reply to CHARGER0_6)
       Post #: 2
RE: balancing biplane - 8/20/2007 9:51:07 PM
khodges
Status: offline
Measure at 1/3 the mean aerodynamic chord; take a point on the centerline even with the upper wing L.E. and a point on the centerline at the lower wing T.E., find 1/3 of the distance from the front mark to the rear mark and transpose it to the underside of the top wing, and balance it there. That should get you in range, you can start from there. Works on every bipe I've ever flown. I think that Cox misprinted something; I agree with gboulton, I've never seen the c/g measured on the bottom wing of a bipe.
Try the point that cox recommends, and hold the plane upside down when you balance it, see if that works. If it does, try my method and see how close the two marks are. Move the c/g forward for more stability, aft for more agility (within a range of about 1/2 inch or so)
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
       Post #: 3
RE: balancing biplane - 8/21/2007 2:26:08 AM
Vintage
Status: offline
Build yourself a Vanessa CG machine and you won't have the problems. Plans are available here on RCU or The House of Balsa Dust.
       Post #: 4
RE: balancing biplane - 9/8/2007 9:16:29 PM
Daren Savage
Status: offline
You would balance on the bottom of the top wing. Usually the balance point is directly above the leading edge of the lower wing. YMMV.
Daren
(in reply to Vintage)
       Post #: 5
RE: balancing biplane - 9/9/2007 12:48:58 AM
gboulton
Status: offline
Since my earlier post, I've discovered the wonder, joy, and elegance that IS the Vanessa CG Machine. Works for ANYTHING you are to name...low wing, high wing, bipes. Little planes or big ones (I balanced my 33% Pitts S2S Bulldog on one). Won't cost ya more than $20 to make, and that's if you have NONE of the material laying around.
(in reply to Daren Savage)
       Post #: 6
RE: balancing biplane - 9/9/2007 2:02:03 AM
Vintage
Status: offline
You can even balance an airplane laterally with the Vanesa. Great machine.
(in reply to gboulton)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
