Giant Scale Newbie looking for experienced advice.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> Giant Scale Newbie looking for experienced advice.
Page: [1] 2   next >   >>
Login
Giant Scale Newbie looking for experienced advice. - 8/20/2007 6:27:12 PM
jfeenin
Status: offline
Hello all.
I am currently looking to build me first giant scale (barely) RC plane. I've flown smaller glow powered 60 and 90 scale Caps, Ultimates, Warbirds and the like before but now I am looking for something a little bigger and gas powered. I am limited to something 78" or shorter because my truck bed is a short one and thats what I have to transport it in.
I've done a lot of looking around and asking a friend who also flies these sized planes and larger (he pointed me here) and I think I have have some idea of the type and size of setup I want but I will throw it out here and see what input those with more experience in this type of aircraft might have to say.
First off I am definitely looking for an ARF. They may not have the worls best build quality compared to a world class builder but I am not a world class builder. Not to mention I have a lot of experience with ARF's and I know what to watch out for with them (glue joints, crap hardware etc.) so I am comfortable going that route.
This is my first gas engine venture too and I will be adding a spread spectrum radio to the mix as well and all tolled it's going to be expensive so I have to get this right the first time.
So given all of that here's the type of basic setup I am looking at to begin with...
Radio - Spektrum DX7
Plane - GP Patty Wagstaff Extra 1/4 scale or Dave Patrick Edge 540 (or similar, exact plane I haven't narrowed down yet but am leaning towards the GP Extra right now)
Engine - Fuji Imvac BT50EI or DA50
Prop - Carbon Fiber Mejzlik of appropriate pitch and size depending on motor chosen. I am also considering CF main gear and tail wheel assemblies.
To this I will add the standard metal gear high torque servos and replace most of the hardware etc.
So my questions are:
- Are those engines appropriate size for decent performance out of this sized plane? I want decent power but I also am wary of too large of a motor and increasing the wing loading to the point the plane is unfriendly. I'd like the thrust:weight ratio of at least 1.5:1 and preferably close to 2:1 but I know I won't quite get there with either of these engines. Should I go with a larger motor, say the BT50EI or something?
- The DA50 lists it's weight at 3.13LBS with standoffs and the Fuji at 4.7 pounds with "Engine, Muffler & Bolt, EIS,Prop Flange & Bolt". Now that's not exactly apples to apples since the DA isn't including the muffler etc. and the Fuji lists it's weight as 3.5 pounds engine alone which makes me think the weight difference may not be all that great in real life installations. So how much heavier is the Fuji BT50EI really in a complete setup vs the DA50-R in a complete setup? Has anyone used both? What about reliability of both? Since where I will be flying is noise sensitive and I will have to be using a canister type muffler anyway the engine only weight means more to me. Would the Fuji be appropriate for this plane? Would the DA be better? Specifically is it the $130 price difference better?
- What about these planes? Are they decent quality ARF's for this size? More importantly are they decent fliers? I don't want to end up with a $1500 plane that I can't land without it wanting to snap roll on me.
I would love to hear comments from people who have these planes and similar engine sizes and hear how they perform.
< Message edited by jfeenin -- 9/6/2007 1:13:38 AM >
_____________________________
Joe
http://starbase4.com/
       Post #: 1
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 7:52:40 PM
bubbagates
Status: offline
The GP Patty actually is very heavy. Since you are looking at Gp anyway, have a look at the Performace Series Cap232 or the Yak. The Cap is a once piece wing so it will be tight but on a DA50 it's a blast. The Yak is also very nice. I jsut did a maiden on one for a firend of mine and he used the Fuji 43 and it did well.
Both planes are in the same price range as the Patty and fly as good or better.
If you really like Ultimates, They also have the Performance series Ultimate that does as good on a 50cc as the other two I mentioned. All three will come in around 14 to 16 lbs on your favorite 50cc and will have balistic performance. The Patty will come in around 17 to 19 lbs ands will have high wing loading.
I all three Perfromace series planes, I have Cap (13.75lbs) and the Ultimate (15.5lb) all with the stock hardware and a Da50 and all are floaters and a blast to fly
Bill James
Normal is not something to aspire to, it's something to get away from
(in reply to jfeenin)
       Post #: 2
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 8:06:38 PM
jfeenin
Status: offline
Yeah, not so into the Ultimate. I saw the Cap and of the planes i have owned my Kyosho 60 size Cap 232 is by FAR my favorite. I guess I was looking for something that was different which is why I looked at the Wagstaff Extra first. Also there seems to be a lot of available information on it out there. Looking at the GP page for that Cap though has me interested. Thanks for the info.
Joe
(in reply to bubbagates)
       Post #: 3
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 8:15:44 PM
jfeenin
Status: offline
So what about the performance of the GP Cap with a Fuji BT50EI? Or is it better with the BT43EI2. I note the 43EI2 is much lighter. The DA-50 is nice but the price premium is large too. I don't mind paying the premium to a point. I don't need the best performing plane on the field to be happy but I'd rather spend $595 and be happy with the plane than $450 and find out it has no vertical at all.
Joe
       Post #: 4
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 8:33:16 PM
bubbagates
Status: offline
Do the 43 for the Cap, it's not as balastic as the 50 will be but the weight will be the same and performance will be nice.
I you want an Extra, look into the Wildhare line. The 28% planes they have are all around 399.99
http://www.wildharerc.com
Bill James
       Post #: 5
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 8:48:26 PM
Richard D Bahmann aka/Wrongway
Status: offline
http://www.dlusa.net/ For $390 you get muffler and ignintion. I have flown one on a friends Great Planes 25% Yak 54 and on another friend's Extreme Flight Yak 54. It has similar power of the DA-50. I like the way it runs.
Richard
To go where no man has gone before...without government permission. In 1938 Wrong Way Corrigan becomes an American Hero.
       Post #: 6
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 9:39:10 PM
bubbagates
Status: offline
Richard,
I totally forgot about the DL50. Yep, decent engine and I admit to having one and loving it and the best thing is all the exhaust parts for a DA50 are a perfect match.
BTW...I'm glad you got the recievers a lot quicker than what it took to get the first one....
Bill James
       Post #: 7
RE: Giance Scale Newbie looking for experienced advice. - 8/20/2007 9:56:32 PM
Status: offline
U.S.P.S. some times we get the scenic route.
Richard
       Post #: 8
RE: Giance Scale Newbie looking for experienced advice. - 8/21/2007 1:21:13 PM
jfeenin
Status: offline
OK now the Wildhare Edge 28% really has me interested... More wing area than the Extra and similar mid-wing design. Also last night talking with my friend he tells me he has a DA50 in his Yak which I have personally seen perform and I think that all but cinched going the extra for the DA on this project for me. I am learning a whole lot about gassers with this project.
So far I have the following notes on issues with gas that glow planes don't have or you wouldn't worry about as much. What else can you guys add/correct:
- Keep ignition wires and switch on the opposite side from the receiver switch.
- Use "fail on" switches.
- Use a 6V Regulator for the receiver and servos.
- Use TWO receiver batteries for safety.
- Use a kill switch in-line to the ignition.
- Normally keep engine servos at least 12" from the ignition but I am told this is not an issue when using a spread spectrum radio and I can then mount the throttle servo in the cowl if I wished without worry. (I will be using spread spectrum)
Other stuff:
- Seal all control surface gaps. I do this on my glow aerobatic planes too thus why it's not above.
- I intend to use a pull-pull rudder with a HS-5955TG or similar servo (rudder only other surfaces will be HS-5645MG). Should I use a bell crank or go direct off the servo arms?
Does all of that seem "sane" to you guys? Am I missing anything glaringly important?
Joe
       Post #: 9
RE: Giance Scale Newbie looking for experienced advice. - 8/21/2007 5:11:49 PM
Hooked-On-RC
Status: offline
Well so far so good, however you may want to look at Aeroworks as well for planes.. Aeroworks They make some really nice ARF kits in a variety of sizes. Extras and Yaks are both available and these are considered high performance aircraft, very lightweight, very well built and nice cover schemes too. I have the 35% Extra QB from Aeroworks and I love how this plane flies. There are a ton of choices out there, but there is also a ton of crap (don't ask me how I know) so just be careful, these forums are a great place to ask and opinion, then again opinions are like ****s, everyone has one...including me!
Hooked-On-RC
"I am not rich enough to buy cheap stuff"
       Post #: 10
RE: Giance Scale Newbie looking for experienced advice. - 8/21/2007 6:06:55 PM
jfeenin
Status: offline
As you may have surmised I do actually know quite a bit about these planes already it's just that this being my first gasser I want to be very cautious with my choices and make sure i get a lot of input and try at least to make informed choices. So far the Wildhare Edge is my leading choice. Assuming I can afford it even when the time comes.
Ironic you mention Aeroworks. Does anyone have an opinion on the 29% Aeroworks Katana-S? How does it fly in comparison to the Wildhare Edge or Extra? I have a source for the Aeroworks plane locally and it may turn out to be a good deal money-wise at that but only if it performs well.
Joe
(in reply to Hooked-On-RC)
       Post #: 11
RE: Giance Scale Newbie looking for experienced advice. - 8/22/2007 9:10:47 PM
jfeenin
Status: offline
Ah another question how does the Evolution 45GX2 compare to the DA50? It lists about the same weight with 5.2HP vs the DA's 5... Are there any issues with the Evo motor?
Joe
       Post #: 12
RE: Giance Scale Newbie looking for experienced advice. - 8/22/2007 9:37:21 PM
CaptDave2
Status: offline
And does anyone have an opinion of the Aeroworks 33% Yak QB or new Extra 260 QB? Compared to the same SD models with HP option?
       Post #: 13
RE: Giance Scale Newbie looking for experienced advice. - 8/22/2007 9:44:11 PM
bubbagates
Status: offline
quote:
ORIGINAL: jfeenin
Don't always go by HP numbers. If you look closely the Hp numbers for Evolution engines are attained in very high RPM numbers which in most cases you will never see. I've seen boith run and own several DA50's. The Da line is by fair the best customer service you will ever see and dead solid. Unless you are really out of tune, a DA engine will continue to run. Evolution and 3W engines tend to not like being out of tune and will complain loudly.
Since this is your first gas plane one thing to remember is do not skimp on anything, which you are already aware of. I've seen your posts in the Cap232 forum and understand our questions which you are doing quite well in the ones you are asking.
BTW, without looking, the Evolution 45 and 50cc engine are the same price so why not get the 50cc version....
Bill James
       Post #: 14
