mj1121
CT, USA Status: offline
Thanks for the input. You can give your opinion any time. My reason for doing this build online was to give others a chance to pass on their experience thru this this thread. In regards to the motorbox, I built it top down over the plans. I dry fit the box and checked to see if everything was square with ONLY the F1 and rear plate in place. Everything looked great, I got alittle full of myself, disassembled everything and then epoxied the F1, rear motorbox plate AND the LG plate . My downfall was the jig I made for this step to keep everything square. That whole keep it simple saying really rings true now. Needless to say, after I removed the jig from hell and checked everything with a builders square, I had a 1/8 inch gap on each side. By this time it had been about 30 minutes since I glued everything together with 30 MINUTE EPOXY and I found myself experiencing some nauesa. I used a thin, fine toothed saw to seperate ( cut ) the LG plate and it's 1/2 by 1/2 hardwood supports from the sides of the box. Little damage was done to the 1/8 inch ply sides but the LG plate was alittle beat up on the edges. I trimmed 1/8 inch off each end and flush mounted it. All measurements are now per the plans. I will add some type of extra support to the LG plate and hardwood stock from the interior of the fuse to make up for this change with little weight gain. The fact that the gear will sit "recessed in" and "flush" with the bottom of the finished fuse was not intended but I think It will turn out with a clean look.
