RE: Carden 40% Edge 540 build ( first time)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Carden 40% Edge 540 build ( first time)
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: Carden 40% Edge 540 build ( first time) - 2/5/2008 11:39:22 PM
as722
Status: offline
quote:
ORIGINAL: mj1121
Hi Albert
I am going to stray from the plans alittle here.
I thought so, just wanted to bring it up just in case.
Albert
_____________________________
Carden Aircraft
(in reply to mj1121)
       Post #: 126
RE: Carden 40% Edge 540 build ( first time) - 2/6/2008 3:02:54 AM
mj1121
Status: offline
Thanks for the heads up. I am prone to jumping ahead of myself. I have no issue with Carden's method of retaining the screws in the elevator, I'm just trying something different.
(in reply to as722)
       Post #: 127
RE: Carden 40% Edge 540 build ( first time) - 2/7/2008 3:53:16 AM
mj1121
Status: offline
I have a few pics of some recent progress. I decided to cut another hole in the lower bellypan near the tail. I also trimmed the wing skins on the elevators and cut both at the hing lines with a razor saw. I then cut the extra material where the 1/2 inch balsa will be used for the hinge points. I made up 1/4 inch plywood for the root caps. I am doing this instead of balsa due to a small change I want to make in the way the elevator is held in place. I am going to use aluminum " dowels" one in front near the leading edge and one near the hinge line for antirotation pins. These will go into hard points in the fuse with some type of sleeve to prevent wear. To hold everything together. I sanded down two small lengths of wood dowel to a tight fit inside the elevator wing tube. I flat spotted the dowel and drilled a hole thru the other side. I ground down a blind nut to fit in the recess and allow the dowel to still slide into the tube. When I have the elevators fit and the incedence set, I am going to put the tail together, drill thru the hole in the hardpoint recessed in the wing, and mark the two holes in the wing tube. I'll then remove the wing tube end drill the holes to the proper size. Then I'll slide the dowels with the blind nuts into the wing tube and line up the holes. The blind nut can't back out or spin due to the snug fit. I had a H9 cap with a similar setup minus the blind nut in the dowel. The hole in the tube ended up stripping out so I hope this will solve that issue. Agian, I just want to make clear that I have no issue with Cardens setup. I came up with this a couple weeks ago and wanted to try it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 128
RE: Carden 40% Edge 540 build ( first time) - 2/7/2008 3:56:51 AM
mj1121
Status: offline
More pics.
Click for fullsize
Click for fullsize
       Post #: 129
RE: Carden 40% Edge 540 build ( first time) - 2/7/2008 3:59:50 AM
mj1121
Status: offline
Two more.
Click for fullsize
Click for fullsize
       Post #: 130
RE: Carden 40% Edge 540 build ( first time) - 2/12/2008 9:02:18 PM
mj1121
Status: offline
I have been working on getting the ailerons cut from the wings. I went with 5 inch by 52 inch instead of 45 inches. Doing this step is not as bad as I thought it would be. I hope to have the balsa caps on all surfaces I cut this evening and I'll post some pics this evening.
       Post #: 131
RE: Carden 40% Edge 540 build ( first time) - 2/13/2008 1:05:54 AM
as722
Status: offline
quote:
ORIGINAL: mj1121
You'll be glad you made the ailerons longer as it will be easier to stop it from torque rolling if you just want to hover.
Albert
Carden Aircraft
       Post #: 132
RE: Carden 40% Edge 540 build ( first time) - 2/13/2008 2:47:03 AM
mj1121
Status: offline
A guy at the field with a Carden suggested longer ailerons than the plans called for just for that reason. I can barely hover long enough to see any rolling but when I get there, the extra length will help. The camera battery is dead so no pics this evening.
(in reply to as722)
       Post #: 133
RE: Carden 40% Edge 540 build ( first time) - 2/19/2008 12:05:19 AM
mj1121
Status: offline
I have been working on the hinge lines for all surfaces. This is taking quite a long time. I will post pics when everything is hinged.
       Post #: 134
RE: Carden 40% Edge 540 build ( first time) - 2/19/2008 12:20:55 AM
mrbigg
Status: offline
quote:
ORIGINAL: mj1121
I don't care for them myself.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 135
RE: Carden 40% Edge 540 build ( first time) - 2/19/2008 1:11:20 AM
mj1121
Status: offline
A real pain in the a**.
(in reply to mrbigg)
       Post #: 136
RE: Carden 40% Edge 540 build ( first time) - 2/19/2008 3:09:53 AM
mj1121
Status: offline
I finally got to forming the hinge lines on on of the main wings. I glued the 3/8 balsa to the wing with gorilla glue then sanded it flush. I them marked the center line and started removing material with a mini plane. I got close then switched to a sanding bar. It actually came out great and I hope to have the others finished soon.
       Post #: 137
RE: Carden 40% Edge 540 build ( first time) - 2/21/2008 1:45:53 AM
mj1121
Status: offline
I took the day off from work today so I was able to really get some work done on the plane. I'm still plugging away at the hinge lines but I only have the elevators left to do. Here are some pics.
Click for fullsize
       Post #: 138
RE: Carden 40% Edge 540 build ( first time) - 2/21/2008 1:48:06 AM
mj1121
Status: offline
Another pic
Click for fullsize
       Post #: 139
RE: Carden 40% Edge 540 build ( first time) - 2/21/2008 1:52:55 AM
mj1121
Status: offline
A couple more.
Click for fullsize
