what is afterrun oil?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> what is afterrun oil?
Page: [1] 2 3 4 5   next >   >>
Login
what is afterrun oil? - 8/23/2007 12:04:50 AM
danamotocross
Status: offline
what is after run oil? do you really NEED it?
       Post #: 1
RE: what is afterrun oil? - 8/23/2007 12:11:35 AM
AllAboutFunHobbies
Status: offline
That's the oil you put in the engine at the end of the day when you are done running the car. You run it out of fuel at the end of the day and put about 4 or 5 drops in the carb and give the pull cord a few pulls to throw it around in the engine. If you don't use after run oil when you are done running then the inside of the engine will rust from sitting with no oil in it.
_____________________________
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
(in reply to danamotocross)
       Post #: 2
RE: what is afterrun oil? - 8/23/2007 12:55:50 PM
{GBI}Harryball
Status: online
Nitro atracks mosture. Dont forget to pull the glow plug and put some in the motor as well. Give the pull cord a couple of pulls to make sure its gets all over the piston.
Sponsered by: ALL ABOUT FUN HOBBIES /ALL ABOUT FUN HOBBIES PRODUCT REVIEWER
(in reply to AllAboutFunHobbies)
       Post #: 3
RE: what is afterrun oil? - 8/23/2007 5:47:04 PM
danamotocross
Status: offline
how will you know if it coats the whole engine?
(in reply to {GBI}Harryball)
       Post #: 4
RE: what is afterrun oil? - 8/23/2007 7:43:41 PM
{GBI}Harryball
Status: online
It will, thats why you pull the pull start a fiew times. You can also use WD40 in it aswell, a one second stream in the carb and the motor will displace all the moisture. Thats what i use.
       Post #: 5
RE: what is afterrun oil? - 8/23/2007 8:14:18 PM
HimotoRacingUSA
Status: online
dont use wd40, use after run oil, wd40 just displaces the water doesnt absorb it, only traxxas reccomends to use it. A bottle of after run costs a couple of dollars and will last a long time. nitro fuel attracts water if left over time in an engine so you want something that will get rid of it, not just move it around.
< Message edited by ehroof -- 8/23/2007 8:20:09 PM >
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
       Post #: 6
RE: what is afterrun oil? - 8/23/2007 11:19:47 PM
AllAboutFunHobbies
Status: offline
You can use transmission fluid for after run oil also it the same thing.
F.Y.I. there no such thing as an oil that removes water, all oils pretty much displace water since oil and water don't mix, there is no way for oil to remove water, it basically displaces the water off of the metal parts.
As long as you are using some sort of thin oil that will coat the metal good you will be good to go. I personally have used WD-40 (fish oil based), 3 in 1 oil, transmission fluid, 5w10 and of course after run oil. THey all produced the same effect, keep the inside pristeen and clean, rust free easy to start next time. I actually have customers that use all sorts of different oils for after run oil and none of them have had a problem. Just make sure you are using some sort of oil when you are done running for the day.
(in reply to HimotoRacingUSA)
       Post #: 7
RE: what is afterrun oil? - 8/23/2007 11:54:37 PM
HimotoRacingUSA
Status: online
well bro, you can use it in your stuff, but i will use after run oil in my stuff, just because you do it doesnt make it right. why would you want to give bad information to peope, especially people who are new to the hobby, why not just give them the proper information.
       Post #: 8
RE: what is afterrun oil? - 8/24/2007 12:34:23 AM
AllAboutFunHobbies
Status: offline
Don't start that crap over here. I'm not gonna play games with you any more like back in the day, you can go around pushing what ever garbgage you want. Just let it spew that's fine. Obviously you don't know what the properties of oil are or else you wouldn't be going around telling people that it makes the water "go away"(whatever that means).
< Message edited by AllAboutFunHobbies -- 8/24/2007 12:38:52 AM >
       Post #: 9
RE: what is afterrun oil? - 8/24/2007 12:39:39 AM
HimotoRacingUSA
Status: online
?? after run oil is designed to use in nitro engies "hence the name" after you run them. WD40 is not, plain and simple. No where on the can does it say to install or put into a nitro engine. why not just tell people the PROPER information and use after run oil? I dont think thats starting trouble.
       Post #: 10
RE: what is afterrun oil? - 8/24/2007 12:41:11 AM
AllAboutFunHobbies
Status: offline
Whatever Ehroof. Do your song and dance I know every thing and every one else is wrong thing.
       Post #: 11
RE: what is afterrun oil? - 8/24/2007 12:43:42 AM
HimotoRacingUSA
Status: online
whatever bro, just give correct information to these guys, they are new to the hobby and need proper information in order to enjoy the hobby.
       Post #: 12
RE: what is afterrun oil? - 8/24/2007 12:55:16 AM
StephenW
Status: offline
w d40 works ok!
       Post #: 13
RE: what is afterrun oil? - 8/24/2007 12:56:44 AM
AllAboutFunHobbies
Status: offline
< Message edited by AllAboutFunHobbies -- 8/24/2007 1:17:24 AM >
       Post #: 14
RE: what is afterrun oil? - 8/24/2007 12:59:54 AM
HimotoRacingUSA
Status: online
LOL wade, the local hobby stores call me for advice. and stephen, i am not trying to start trouble, i just want you to use the correct stuff and enjoy the hobby, wd40 is not the correct thing to use as after run oil.
       Post #: 15
RE: what is afterrun oil? - 8/24/2007 1:09:24 AM
AllAboutFunHobbies
Status: offline
ROTF, of course they call you, why wouldn't they.
       Post #: 16
RE: what is afterrun oil? - 8/24/2007 1:13:48 AM
HimotoRacingUSA
Status: online
i wont argue with you wade, just make sure you give these guys the right information when they ask
       Post #: 17
RE: what is afterrun oil? - 8/24/2007 1:17:45 AM
AllAboutFunHobbies
Status: offline
I don't think you have to worry about that, I'll be sure to call you first for advice.
