Royal Corsair .60 project
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Royal Corsair .60 project
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
Royal Corsair .60 project - 5/21/2003 8:53:38 PM
foxx
Status: offline
diony you got my vote on that , you forgot to mention the weight of the servos at the wing tip create unwanted momentum on spins and rolls (dumbbell effect) and increase the tendency to tip stall.
_____________________________
One of the senior members
(in reply to dionysusbacchus)
       Post #: 76
Royal Corsair .60 project - 5/21/2003 9:39:13 PM
dionysusbacchus
Status: offline
[QUOTE]Originally posted by foxx
diony you got my vote on that , you forgot to mention the weight of the servos at the wing tip create unwanted momentum on spins and rolls (dumbbell effect) and increase the tendency to tip stall. [/QUOTE]
Excellent points foxx, keep those wing tips light! Maybe the jet movement started this? They make some excellent quality bell cranks now with brass bushings, really nice, no reason not to use them.
Luke
       Post #: 77
Royal Corsair .60 project - 5/22/2003 5:11:58 AM
SVX
Status: offline
Well I am just in awe. I am actively following your site and find it very inspirational.
I hope my question isn't to "beginner" but I would like to try putting gear doors on my next project and would like to use fiberglass for the material. However I saw Platt do his doors over a sheeted surface, then after the fiberglass was laid he cut out the sheeting for the retracts and wheels. Is this the way you did it?
Once again thanks for sharing your experiences. I look forward to the finished project.
SVX
       Post #: 78
Royal Corsair .60 project - 5/22/2003 7:49:35 AM
dionysusbacchus
Status: offline
Thank you SVX, inspirational is a two way street, the encouragement I get from people like you and the rest of the guys here at RCU has helped tremendously! Thanks again.
I just talked to Dave Platt this evening as a matter of fact! Yes he is a member of the IRKS here in Florida, we had a club meeting tonight. I brought my Corsair, I was happy to have Dave say I did a good job, that means a lot! This is bragging I know, but I'm tickled to have him in the club!
[URL=http://www.irks.org/]IRKS[/URL]
Dave knows what he is doing, I did it the easy way however. I sheeted the bottom of the wing, Monokoted it then put the glass down over the Monokote. On my site I explain how I did the tail wheel doors, well I did the mains in the same way.
Keep checking back!
Luke
Click to see fullsize image.
Click for fullsize
       Post #: 79
Royal Corsair .60 project - 5/22/2003 7:50:46 AM
dionysusbacchus
Status: offline
Glass down:
Click for fullsize
       Post #: 80
Royal Corsair .60 project - 5/22/2003 7:51:31 AM
dionysusbacchus
Status: offline
Mark out the doors:
Click for fullsize
       Post #: 81
Royal Corsair .60 project - 5/22/2003 9:56:28 AM
SVX
Status: offline
Got it thanks, by the way congrats on the approval from Platt you earned it.
SVX
       Post #: 82
Royal Corsair .60 project - 5/23/2003 4:49:54 AM
jhess
Status: offline
I have had two royals over the years. Great flying Bird. Lots of work though. Good news . If you can build that thing . you can build just sbout anything.
JIM Hess
Blue Skies
JimHess
       Post #: 83
Royal Corsair .60 project - 6/5/2003 10:18:03 PM
dionysusbacchus
Status: offline
Thanks Jhess,
With the old Royal/Marutaka kits it helps to know what you are going to do and how to do it!
Been getting the wing ready to glass, tightening up the gaps and filling the dings. I always glass the wing first so that I can get a good fit to the fuselage.
I have been looking for a good muffler to use, but none fit the way I want them to. I may want to add scale exhausts, so I decided to make my own using the Top Flite exhaust header coming off the engine. I used aluminum brazing, it actually welds the aluminum, very strong. You can burn a hole through the aluminum, so you have to be careful.
Here is a picture of the muffler test fitted, I am going to make plywood mounts and hold it on with metal straps. Thin strips of rubber will fit between the straps and the muffler.
Luke
Click for fullsize
       Post #: 84
Royal Corsair .60 project - 6/5/2003 10:19:26 PM
dionysusbacchus
Status: offline
Keep in mind that no new information will be added to the Corsair Project page, it is full. I will only add new information to my main page.
This is how my home made muffler looks:
Click for fullsize
       Post #: 85
Royal Corsair .60 project - 6/6/2003 5:17:23 AM
dionysusbacchus
Status: offline
This is how the simulated "fabric" will look on the outer wing panels. It might be exaggerated, but it's not always about what is right as much as does it look right. I am modeling a war weary Corsair, so all the stress and G forces on the fabric have stretched it and caused it to sag!
Click for fullsize
       Post #: 86
Royal Corsair .60 project - 6/6/2003 5:38:25 AM
Rocketman612
Status: online
Luke,
Your wing looks great when are you coming over to do mine Pete
"Remember, all im offering is the truth, nothing more..."
Morpheus
       Post #: 87
Royal Corsair .60 project - 6/6/2003 2:34:55 PM
dionysusbacchus
Status: offline
[QUOTE]Originally posted by Rocketman612
Luke,
[/QUOTE]
Hey Pete, thanks but no thanks! With 4 simulated fabric areas per wing and several other Corsairs to build, I'm booked! (and tired!)
How's your Corsair coming along, ain't seen anything from you in a few days?
Luke
Click for fullsize
       Post #: 88
Royal Corsair .60 project - 6/6/2003 5:12:31 PM
dionysusbacchus
Status: offline
Any muffler experts out there that can comment on my exhaust system? Back pressure, pressure fitting, length of the exhaust stacks etc etc?
Got the pressure nipple in and mounted on the ply cradle:
Click for fullsize
       Post #: 89
Royal Corsair .60 project - 6/9/2003 12:07:41 PM
Devo
Status: offline
dionysusbacchus, I'd simulate tank location and bench run your engine with your exhaust and whatever exhaust you used that worked well on this engine before. Tach your engine with each one, leaving all other variables the same. Bench running will also give you the ability to check the temperature of your exhaust. It's the best way of knowing how it will perform, short of flying with it. How about a better view of the outlet pipe?
I see that you have an aluminum cowl. Do you plan to open the cowl flaps? If so how do you plan to form them? What other means of cooling do you plan, if any? When it comes to exhaust, I always consider the heat factor. It would seem that a system with more surface area would expel more heat inside the cowl. Unfortunately two stroke engines tend to like more expansion area. Run it!
I've got high friends in places.
       Post #: 90
