dionysusbacchus
ND, USA Status: offline
[QUOTE]Originally posted by shupack looks great so- far, i've never seen the royal plans, but i have a copy of ziroli, i'm doing that next, what's different about the wing centre section? that looks like a secondary spar insead of a TE spar, where will the wing bolts go, and is the belly pan removable? also, where can i get a copy of the tailwheel plans? [/QUOTE] Thanks Shupack. I have the Ziroli plans also, I haven't looked at them in a while though, the only thing I don't like about the Ziroli is the front of the fuselage and I really hate the Ziroli fiberglass cowl, yuk!! Before everyone attacks me that is just my opinion based on comparisons with the full scale bird. The Royal wing does have a secondary spar, this is one of the many ways that it is superior to the Top Flite kit. It gives you a clean uncluttered rear wing to put the flaps in, and make them the scale size. The wing bolts will go at the rear of the center section, a wedge shaped block will be glued in, and no I am not making the bottom wing fairing removable. I knew the "Where can I get plans" question was coming. You can't get these plans anywhere that I know of. I may draw a set up for distribution, I just want to get this plane done first. Luke (dionysusbacchus)
