New SPAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> New SPAD
Page: [1]
Login
New SPAD - 8/24/2007 1:04:50 PM
CATA
Status: offline
Here is my new Carlspad. I wanted to build a sport / pattern type plane. The wing is actually developed from the wing on my Edge 540.
Wing span = 60"
Wing Root = 12"
Wing Tip = 10"
MAC = 11.03
Area = 660 sq. in
Wing Aspect = 5.45
CG = 4.5
Weight 6.25 lbs
Wing Loading = 20 oz/ft
Wing thickness max 2" tapers to 1" at tip
Wing spar one piece popular with 2 degrees of dihederal
Fuse length = 55"
Horizontial stab = 22"
Vertical stab 12 base 7 at tip including rudder
The plane is powered with a .61 ASP
The plane flies very well, it does loops, spins, knife edge, axial rolls
Plane has very mild stall, nose drops slightly, with no wing tip stall
Landing speed can be slow, likes a little power on
I have 50 + flights on this plane with no problems or failures
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Charles Ayer
       Post #: 1
RE: New SPAD - 8/25/2007 12:51:11 AM
DLSmith2
Status: offline
What a beauty! Great job on the plane and graphics!
Are you propped for speed or torque?
Blue skies,
DL
(in reply to CATA)
       Post #: 2
RE: New SPAD - 8/25/2007 1:41:24 AM
CATA
Status: offline
DL
thanks
I have a 12x6 propon the ASP 61 it seems to be a good comprimise of power and speed at least for me.
CA
Charles Ayer
(in reply to DLSmith2)
       Post #: 3
RE: New SPAD - 8/25/2007 1:42:27 AM
CATA
Status: offline
DL
thanks
I have a 12x6 prop on the ASP 61 it seems to be a good comprimise of power and speed at least for me.
CA
Charles Ayer
       Post #: 4
RE: New SPAD - 8/25/2007 4:22:31 AM
MrGreenSpeed
Status: offline
Fantastic looking Spad, Charles
Thanks for sharing
Jeff
(in reply to CATA)
       Post #: 5
RE: New SPAD - 8/27/2007 1:28:03 PM
TruBlu02
Status: offline
Very cool plane! I love the landing gear as well.
(in reply to MrGreenSpeed)
       Post #: 6
RE: New SPAD - 9/19/2007 9:24:27 PM
YSN
Status: offline
This fery nice but look like balsa plan, i saw from rudder
(in reply to TruBlu02)
       Post #: 7
RE: New SPAD - 9/22/2007 9:56:25 AM
mikenlapaz
Status: online
very impressive - nice work Just crate it up and send that ole plane on South and you can start on another one!!!
''A government big enough to give you everything you want, is big enough to take away everything you have.'' Thomas Jefferso
(in reply to YSN)
       Post #: 8
RE: New SPAD - 9/22/2007 1:19:23 PM
Smooth Spanky
Status: offline
Cata:
Are you SURE that's a SPAD? None of my stuff ever looks even close to being that nice.
Very well done...thanks for posting the pics.
Smooth
(in reply to mikenlapaz)
       Post #: 9
RE: New SPAD - 9/22/2007 3:20:11 PM
YSN
Status: offline
I Thing It's Not pure SPAD
(in reply to Smooth Spanky)
       Post #: 10
RE: New SPAD - 9/22/2007 10:01:56 PM
OzMo
Status: offline
SPAD RULE #1 Use what you got!! pure enough
Balsa = organic coroplast
Yes dear, I did glue my hand to the airplane to keep from dropping it.
(in reply to YSN)
       Post #: 11
RE: New SPAD - 9/23/2007 1:53:23 AM
MrGreenSpeed
Status: offline
The idea that drives Spad is use what You have to get in the air.
Look close, it's more Spad than You think
This one was built by ChrisSpad and it's pure Spad.
Here is a link to the build pics.
http://www.chrisspad.com/planes/main/mydesigns/corocap/gallery.html
Jeff
(in reply to OzMo)
       Post #: 12
RE: New SPAD - 9/23/2007 4:13:29 AM
OzMo
Status: offline
It looks CAVERNOUS..... Carlspad caverns???? I know that was really bad
       Post #: 13
RE: New SPAD - 10/2/2007 12:09:20 PM
CATA
Status: offline
The Carlspad is made completly from coroplast, except I used balsa for the ailerons to save weight and add stiffness. The frame is made from 1x 1/4 popular attached to the firewall running back to the stat of the wing saddle. I used two pink foam formers for the back of the fuse. I made the turtle deck from foam covered with sign vinyl.
CATA
Charles Ayer
(in reply to CATA)
       Post #: 14
RE: New SPAD - 10/5/2007 8:26:16 AM
MrEdge
Status: offline
I know this is prolly beat to hell in other threads but, where are you all getting the American PVC from..What kind of stores sell it?
(in reply to CATA)
       Post #: 15
