painting wheels
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> painting wheels
Page: [1]
Login
painting wheels - 8/24/2007 9:35:39 PM
zimm11
Status: offline
Title says it all how do i make a white wheel black.
_____________________________
(: ʞɔnן pooƃ - ʇı pɐǝɹ uɐɔ noʎ ɟı ǝןıɟoɹd ɹn sı sıɥʇ ʇnd
       Post #: 1
RE: painting wheels - 8/24/2007 10:29:49 PM
bluecaka69
Status: offline
dye it with rit dye here some i dyed pink for my wife
here a link with picture and remember not to cook to long as parts will melt
http://www.lynxmotion.com/images/html/build008.htm
: All nylon parts can be dyed with outstanding results! This includes parts that are natural white, yellow, blue, etc. The key to remember is that you can only dye a part darker than its current color. For example, a yellow part can be dyed orange, red, green ,blue, purple, etc., yet a blue part can only be dyed a darker shade of blue, dark purple or black.
To get started, simply boil some water, add some Rit™ clothing dye of the color you want the parts to be to the boiling water, and then place your new RPM dyeable parts in the water. Be sure that the dye is completely saturated in the water before adding your parts! The depth and shade of the color will vary depending on time left in the water/dye solution, the amount of dye used, and the temperature of the water. Usually, higher concentrations of dye darken the color of the parts faster, as will higher water temperatures. Use caution because the parts will look lighter in color when first removed from the hot water. When the color looks close, but still slightly lighter than what you want, remove the parts from the water/dye solution and let them cool. They will darken slightly after cooling. If they aren't quite dark enough at this point, place them back in the solution for a brief time until the color is to the tint of your choice.
Important note: To make all of your parts identical in color, either dye all of them at the same time, or take careful notes during the dyeing process such as;
1) Water temperature (i.e. fast boil, slow simmer, etc.).
2) Amount of dye and water used.
3) Type and manufacturer of the dye.
4) Time the parts spent in the dye solution.
Additionally: Because this is a dyeing process of the parts, and not a plating process, the dye will have absolutely no effect on the adhesive bond when tires are glued to our dyeable wheels.
You can also dye your chrome parts with amazing result
Bodies By Blue-Airbrushes Bring Out The Artist In All Of Us!!
All About Fun Hobbies
(in reply to zimm11)
       Post #: 2
RE: painting wheels - 8/27/2007 5:19:09 PM
KSTwinger
Status: offline
Outstanding results, nice idea thank you.
       Post #: 3
RE: painting wheels - 8/27/2007 6:10:47 PM
rcluke
Status: offline
where do you get the dye from?
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
(in reply to KSTwinger)
       Post #: 4
RE: painting wheels - 8/27/2007 7:03:41 PM
Nick2618
Status: offline
quote:
ORIGINAL: rcluke
Well you are in the UK but here you can get it at Walmart, and craftstores. And even most grocery sotres.
< Message edited by nick2618 -- 8/27/2007 7:04:09 PM >
Florida Gods Waiting RoomCheck Gallery for Pictures
Jato 3.3 |Cen Nemesis (working...) |Lunchbox |ST-15 |Mario Kart D
(in reply to rcluke)
       Post #: 5
RE: painting wheels - 8/27/2007 7:08:07 PM
Nick2618
Status: offline
Heres a shot of some dished wheels diyed black.
Also some tips. Get a stick and some dental floss. THen tie the floss to the stick and the rims that way you can dip them in and out. Also get the water to a boil and add the dye then turn down the heat until it is just a simmer that way you do not make a mess.
Click to see fullsize image.
Click for fullsize
(in reply to Nick2618)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.523RCU1
