Castor oil, castrol M
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Castor oil, castrol M
Page: [1]
Login
Castor oil, castrol M - 8/25/2007 5:44:24 PM
Sir-Ipswich
Status: offline
Where can I get it from? I live in the UK in Ipswich, (hense Sir-Ipswich)
       Post #: 1
RE: Castor oil, castrol M - 8/25/2007 7:31:10 PM
NikolayTT
Status: offline
In the Drug store, ask for quantity like one gallon - it would be the best price, in range of 15 Euro per gallong
or better visit some factories where they make some products out of it - then price is about 4x lower;
For type of products and factories you can check this:
http://en.wikipedia.org/wiki/Castor_oil
(in reply to Sir-Ipswich)
       Post #: 2
RE: Castor oil, castrol M - 8/25/2007 7:42:53 PM
gkamysz
Status: offline
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9014107&contentId=7027099#7094386
A good racing castor will have additives to reduce ash and varnish. Check a motorcycle shop. That is where they are commonly available in the US. Castrol M is not available here.
_____________________________
Greg
(in reply to NikolayTT)
       Post #: 3
RE: Castor oil, castrol M - 8/26/2007 3:39:54 AM
downunder
Status: offline
I've been using Castrol M for about 50 years and I can tell you it's good stuff!! And it should be too because Castrol started making it 100 years ago in England. Even their name comes from castor oil. I get it for $8 a litre which is a bit over 3GBP.
(in reply to gkamysz)
       Post #: 4
RE: Castor oil, castrol M - 9/20/2007 10:07:29 AM
the pope
Status: offline
Hey downunder , where do you get your castor from? From memory the place I get my methonal and nitro from (Scothers at Wingfield) was selling castrol castor for about $55 for 4.5 litres. I have been buying castor from a model shop buy the litre but this caster has additives to protect against varnish etc. Do you know what these are and are they any better than using just straight castor? cheers the pope
(in reply to downunder)
       Post #: 5
RE: Castor oil, castrol M - 9/20/2007 3:10:38 PM
downunder
Status: offline
Hey pope,
I get my castor from a guy in our club (Holdfast) who mixes fuel for ModelFlight and gets it in bulk. Scotchers has very good prices for methanol but if you know where the Noarlunga field is (turn left at the first set of lights when you get on South Road from the Vic Harbor road) then there's a Caltex fuel depot a few hundred metres along Seaford Rd (8386 1055). They've always had Castrol M there too but the price tends to vary a bit. Anyway, it might save you a trip right across town .
I'd be wary of any castor that's supposed to cut down varnish because that's its last ditch protection against lean runs.
(in reply to the pope)
       Post #: 6
RE: Castor oil, castrol M - 9/20/2007 5:17:57 PM
blw
Status: offline
Good point about the protection part.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 7
RE: Castor oil, castrol M - 9/22/2007 3:21:39 AM
the pope
Status: offline
Thanks for the info Downunder I know where you are talking about as I used to live in the area ( Morphett Vale ) I will call in and see about the caster next time I am in town. I have stopped in at holdfast once to have a look but I havent been to Noarlunga yet for a look. From what ive been told its a pretty pokey place to fly. Maybe Iam just spoiled by the wide open space of Strath. Do you ever come done and fly at strath ? Thanks again for the info. Cheers the pope
(in reply to blw)
       Post #: 8
RE: Castor oil, castrol M - 9/22/2007 4:16:25 PM
downunder
Status: offline
Yep, Noarlunga is pretty pokey to fly from and you have to be careful of the full size strip and hangars close by. The best thing about it is all the roos that gather in the field alongside in the evenings....the worst thing is the calling cards the roos leave on the flight line each night .
But an update on methanol from that depot near the field. My son got some the other day and it was $50 for 20 litres so you're better off going the extra distance to Scotchers.
       Post #: 9
RE: Castor oil, castrol M - 9/23/2007 4:22:04 AM
1705493-AndyW
Status: offline
quote:
ORIGINAL: downunder
Will it mix with kerosene without the need for ether?
Andy Woitowicz
       Post #: 10
RE: Castor oil, castrol M - 9/24/2007 10:29:26 AM
the pope
Status: offline
Hey downunder the price for the methanol does seem pretty pricey, I paid $63 for 2 litres of nitro and $14 litres of methanol and from memory the nitro was $20 p/l. As for the kangaroos I bet they bugger off when you bring out the barb-e-que. Cheers the pope.
       Post #: 11
RE: Castor oil, castrol M - 9/25/2007 7:41:53 AM
the pope
Status: offline
Holy crap, downunder I just rang to see if the fuel depot had any castor and was quoted $83 bucks for a can of castor. After picking myself off the floor I`ve decided to go electric ( just kidding) now if any body knows where I can get castor anywhere in the Adelaide area reasonably cheap I would love to know. Cheers the pope
       Post #: 12
RE: Castor oil, castrol M - 9/25/2007 2:22:39 PM
downunder
Status: offline
I gather that's $83 for 5 litres? Phew! I'll check my local supplier and see if it's still $40 for 5 litres...I need some anyway .
       Post #: 13
RE: Castor oil, castrol M - 9/25/2007 11:12:33 PM
AMB
Status: offline
Downunder you guys will have to Potty train the roos , hi from wet Florida martin
       Post #: 14
RE: Castor oil, castrol M - 9/26/2007 6:54:10 AM
the pope
Status: offline
Howdy Dan, with the price of castor oil I wont be feeding them castor thats for sure.Imagine trying to pick that mess up Cheers the pope.
(in reply to AMB)
       Post #: 15
RE: Castor oil, castrol M - 11/17/2007 4:42:22 AM
