RE: Savex L-39 as EDF
Tower Hobbies
Logged in as Guest
  Printable Version
Jet Hangar Hobbies LTV A-7 Corsair II - RTF
Seller:  mikegpresario
Details:   $2,850.00   |  8/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Savex L-39 as EDF
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Savex L-39 as EDF - 3/5/2008 7:30:07 PM
Neil Guildford
Status: offline
Thank you for your reply's
Reinhard: That is exactly what I was thinking I would need to do. I hope I can do that with my FF9.
carlrich: The Vampire is a super plane..I'm hoping this will also be.
Neil
(in reply to Rliebl)
       Post #: 76
RE: Savex L-39 as EDF - 3/5/2008 8:40:17 PM
carlrich
Status: offline
You're going to love this L39. Super easy to fly and can be quite fast. Flaps are great for slowing it down. Handles extremely well in the air. I'm about to place an order for the Vampire so I hope I can get some speed out of it.
(in reply to Neil Guildford)
       Post #: 77
RE: Savex L-39 as EDF - 3/5/2008 10:32:50 PM
Neil Guildford
Status: offline
My Vampire isn't that fast, but is great to fly. You could easliy put 8 cells in one and push near 2K if you wanted. The landing speed is mega slow if you want it to be.
Neil
(in reply to carlrich)
       Post #: 78
RE: Savex L-39 as EDF - 3/6/2008 11:17:24 PM
Neil Guildford
Status: offline
I've just played around with a mix and after an hour of trial and error I found it is possible with my FF9....great!
This means my setup will be as follows:
1: Aileron on a Y-Lead
2: Elevator 1
3: Throttle
4: Rudder
5: Flap 1
6: Flap 2
7: Elevator 2
8: Rudder nose gear
9: Retracts
I think I may use a Lipo to power this lot through a regulator.
Neil
< Message edited by Neil Guildford -- 3/6/2008 11:18:04 PM >
       Post #: 79
RE: Savex L-39 as EDF - 3/7/2008 12:34:52 PM
Dave03B
Status: offline
quote:
ORIGINAL: Neil Guildford
Has anyone found that the nose gear can cause the steering servo to stall when up?
I'm just installing mine and can't find a good location for the servo....any close ups would be really helpful.
I'm using the Jet 1A forward retracting version.
Thanks, Neil
L-39 Neil? Good choice! :-)
_____________________________
Dave Bright - www.wimbornemac.org
       Post #: 80
RE: Savex L-39 as EDF - 3/7/2008 2:01:59 PM
Neil Guildford
Status: offline
Hi Dave, how you been? I see your selling yours.
(in reply to Dave03B)
       Post #: 81
RE: Savex L-39 as EDF - 3/7/2008 2:10:15 PM
Dave03B
Status: offline
Fine thanks mate. Not selling mine now as I've found a way to improve the way my retracts handle my awful grass field. I forsee no further takeoff/landing problems!
How things with you? lil un ok?
When you flying this L39? I flew mine last week and forgot how much I love it!!
       Post #: 82
RE: Savex L-39 as EDF - 3/8/2008 9:43:58 AM
Neil Guildford
Status: offline
Its nearly finished and I've just done a CG check with my packs. I'm guessing 80mm from the LE of the wing at the fuz is what people are flying with.....it just seems a little far forwrad.
Mine is looking like an AUW of 10lb with 10S 5000's and a NEU Motor 1515/3D. I hope the extra power overcomes this extra weight.
Neil
       Post #: 83
RE: Savex L-39 as EDF - 3/8/2008 10:36:36 AM
carlrich
Status: offline
Neil, L39 flies great at 80mm CG. I can't say what would happen if you move it back some. I'm just over 9lbs. When you get a chance to check watts, amps and thrust please post. I don't want to dilute this L39 thread about the Vampire. Would you have a look at my question on your Vampire thread?
Vampire thread,
http://www.rcgroups.com/forums/showthread.php?t=769816&page=7#post9310308
< Message edited by carlrich -- 3/8/2008 10:37:54 AM >
       Post #: 84
RE: Savex L-39 as EDF - 3/9/2008 10:25:45 PM
Neil Guildford
Status: offline
I just ran some very quick tests on cold (about 10deg) packs and got the following:
69A
2450W
3.4kg of static thrust - on not very acurate scales.
The model feels very light when held nose up on full power and only slowly falls down. As long as the model can handle this type of wing loading (10.5lbs) it should fly well.
Neil
< Message edited by Neil Guildford -- 3/9/2008 10:28:46 PM >
       Post #: 85
RE: Savex L-39 as EDF - 3/10/2008 11:39:29 AM
Dave03B
Status: offline
Neil, my 44 powered version is 11lbs at takeoff and flies beautifully. Make sure you have your takeoff flaps set as they do really help.
When you flying her?
       Post #: 86
RE: Savex L-39 as EDF - 3/10/2008 3:38:25 PM
Neil Guildford
Status: offline
Hi Dave
Hope you got my email the other day.
What flap settings do you use for take off and landing? Have you needed to couple any elevator?
I will be taking her up for a maiden as soon as the weather is better, probably this Saturday or Sunday.
How much thrust do you get from the 44?
Neil
       Post #: 87
RE: Savex L-39 as EDF - 3/11/2008 8:55:43 PM
Dave03B
Status: offline
Hi Neil, yes thanks for your email the other day. Gongrats on the second lil 'un, very pleased for you. Suprised you have any money at all for all this stuff :-)
I have about 15degrees for takeoff flap mixed with a small amount of down elev. for landing flap, use as much as you can get, and mix 2/3mm down elev to prevent ballooning. I have max about 40degrees on landing flap. With the upgraded 44 and my special thrust pipe im getting approx. 10lbs.
Im going to recheck my cg as I think I intially set it to 80mm but found during recent flights that it doesn't seem to 'sit' nicely in the air, so I may move it slightly.
       Post #: 88
RE: Savex L-39 as EDF - 3/14/2008 11:29:23 PM
Neil Guildford
Status: offline
I managed to squeeze a maiden in today. There was no wind and our strip hasn't been cut for months. Its been raining heavily for a few days so the drag was rather alot. That being said it got off.
The flight was 5.5 mins long and I used 3000mah from the 5000mah packs. The power in flight was very good and its handling is rock solid. I had a few semi lockouts which I will address but for tomorrows flights I will be taping the aerial to the fin.
My landing could have done with a final flair but the sprung Jet 1A retracts did their thing and took out the bounce.
Can't wait for my next flight so I can start seeing what its capable of.
Video here:
http://media.putfile.com/Savex-L-39-Maiden
Neil
< Message edited by Neil Guildford -- 3/14/2008 11:31:02 PM >
       Post #: 89
RE: Savex L-39 as EDF - 3/15/2008 9:02:35 AM
Rliebl
Status: offline
hi Neil,
congrates to your maiden,
another L 39 EDF is born
happy landings
Regards
Reinhard
Reinhard
My flying Club www.mfc-mettenheim.de
