Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >>
Page: [1]
Login
- 3/17/2003 7:53:45 AM
mpj220
Status: offline
No longer support RCU
< Message edited by mpj220 -- Aug 4 2003 10:47PM >
       Post #: 1
- 3/17/2003 9:10:02 AM
epc
Status: offline
mpj 220:
I have the same engine so I think I can help you a litle bit.
1- 50:1 any good 2 stroke engine Amsoil , red line ( I'm using Motul racing on mine )
2-That will depend on the batt. capacity I think you should use at least a 1000 mah. 4.8 batt. pack.
3.Very easy to start hand flip , For the choke you can use a servo if you want but it is not necessary just use a piece of wire and do it manually.
4-20x10 is a good prop the one that I found to be the best for this engine is the Menz S 20x10.( Also the mejzlik 20x10 )
5- Yeah two needles The one with the H beig the high and the other one L low setting. H 1 1/2 and L 3/4-1 more or less depends on your weather and altitude.
6-Tru turn , Dave Brown. ( I like the tru turn and they sell it alredy drilled for 3w engines if you want ).
Hope this helps.
epc.
(in reply to mpj220)
       Post #: 2
- 3/17/2003 6:45:40 PM
mpj220
Status: offline
< Message edited by mpj220 -- Aug 4 2003 10:48PM >
       Post #: 3
- 3/17/2003 7:08:39 PM
epc
Status: offline
The High " H " is the one in the front closer to the prop hub, and the low is the one on the back.
epc.
       Post #: 4
- 3/18/2003 3:00:31 AM
mpj220
Status: offline
< Message edited by mpj220 -- Aug 4 2003 10:49PM >
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU2
