RE: 35% Extra 260 on tuned pipes thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 35% Extra 260 on tuned pipes thread
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: 35% Extra 260 on tuned pipes thread - 9/30/2007 12:31:06 PM
Scoubidou
Status: offline
pic
Click to see fullsize image.
Click for fullsize
_____________________________
Seneca Engineering
http://www.seneca.ca/
(in reply to Scoubidou)
       Post #: 26
RE: 35% Extra 260 on tuned pipes thread - 9/30/2007 12:36:36 PM
Scoubidou
Status: offline
I have to sheet the top/bottom fuse before building the pipes tunnel.
Daniel
Click for fullsize
Click for fullsize
Seneca Engineering
       Post #: 27
RE: 35% Extra 260 on tuned pipes thread - 10/7/2007 2:41:27 AM
Scoubidou
Status: offline
Hi guys
I am doing the holes in the wings for the ailerons servos but there is only 1/4''x1/2'' brasswood included in the kit. I plan to use 2x JR8411/ailerons.
May i use only 2'' long brasswood or should i built servo boxes with plywood for the servos?
Daniel
Seneca Engineering
       Post #: 28
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 1:29:59 PM
Bobt2
Status: offline
i will look foward to a flight report.i built the first 35%260 with the k&s rear exaust cans. at 27 lbs i have all the power i need. with these pipes will you still use a28x10 prop?
       Post #: 29
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 1:34:22 PM
Scoubidou
Status: offline
Hi Bob
Yes i am going to tune it for Mejzlick 28x18. I have an eye in Advance (IMAC) for 2008 and i need the maxium power i can get for the long vertical uplines/snaps. Like i already said, we need more power for IMAC than 3D. The MTW tuned pipes cost is about the same of the cans without weight penalty but a lot more power and less noise.
Seneca Engineering
(in reply to Bobt2)
       Post #: 30
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 2:45:29 PM
Scoubidou
Status: offline
The litle syringue was very useful for the sheeting. Not so bad for my first sheeting experience
Click for fullsize
Click for fullsize
Click for fullsize
Seneca Engineering
       Post #: 31
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 2:48:02 PM
Scoubidou
Status: offline
This thing needs more weight than i tought.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Seneca Engineering
       Post #: 32
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 2:50:45 PM
Scoubidou
Status: offline
On the second wing i used a dremel tool to make servos holes and i got better results than hot wire.
Click for fullsize
Click for fullsize
Seneca Engineering
       Post #: 33
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 2:52:01 PM
Scoubidou
Status: offline
This kit is like drug. I can not stop building it
Ciao!
Click for fullsize
Seneca Engineering
       Post #: 34
RE: 35% Extra 260 on tuned pipes thread - 10/14/2007 4:47:30 PM
capflyr
Status: offline
This fourm is like A drug I cant stop reading, keep up the good work Scoubi and good luck.
       Post #: 35
RE: 35% Extra 260 on tuned pipes thread - 10/15/2007 12:12:23 AM
Bobt2
Status: offline
with my set-up and the 28x10 it flies the unlimited with ease! but is that a misprint? 28x18?
(in reply to capflyr)
       Post #: 36
RE: 35% Extra 260 on tuned pipes thread - 10/15/2007 12:52:43 AM
Scoubidou
Status: offline
Yeah, i meant 28x10.
I would like to have a plane with more than enough power to do all that i want, whatever the condtions hot/cold. Everytime i ask recommendations to engine manufacturer about exausts, they propose ''tuned pipes'' for better throtle response, noise, and power.
Seneca Engineering
(in reply to Bobt2)
       Post #: 37
RE: 35% Extra 260 on tuned pipes thread - 10/15/2007 3:08:03 AM
krayzc-RCU
Status: online
i like what i am seeing keep up the good work
smooth as silk!
       Post #: 38
RE: 35% Extra 260 on tuned pipes thread - 10/26/2007 2:37:33 AM
Scoubidou
Status: offline
I received the CF gear today:
Graptech: 9.6oz
Carden: 20oz
Saving: 10.4oz=0.65 pound
Cost: 69$
Click for fullsize
Seneca Engineering
(in reply to krayzc-RCU)
       Post #: 39
