bigtim
CA, USA Status: offline
the Mustang is looking good so far. for those looking for DEFT brushing laquer,you do not need the sanding sealer, the satin finish works just as good for sealing balsa and sands to a smooth finish after 2 coats. in Calif, the sanding sealer is pretty much gone from the market unless you want to buy it in spray cans and it isn't as good as it used to be. the satin and gloss finish product is still available in most areas,but your going to have to go to a paint dealer to get it,I get mine at the local Benjamin Moore store,I haven't found it in any of the Home Depot stores that I use, its really becoming a specialty item. being a contractor I deal with these products all the time. I am curious to see how the silver metalic comes out, I use a similar product called modern masters metalics its also a latex,water clean up and works pretty good,but I have read that the Behr works well also, looking forward to seing the results.
