Glassing a warbird for the first time
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Glassing a warbird for the first time
Page: [1] 2 3   next >   >>
Login
Glassing a warbird for the first time - 8/28/2007 3:13:51 PM
7aso
Status: offline
I will be glassing my 1/5th all wood P-51 this week. It will be my first time doing this. I went with the Midwest Microglas Cloth with Zap Z-Poxy Finishing Resin. Before I start, I would like to know:
What are the basic step-by-step instructions to go about glassing?
What area(s) should I start with first?
Can I cover the whole plane in one session, let it dry, then repeat again?
Can I use a latex paint such as krylon? If so, spray or brush?
Do I need to clearcoat it?
Anything else I left out please fill in. Thank you.
_____________________________
Warbirds or nothing
       Post #: 1
RE: Glassing a warbird for the first time - 8/28/2007 3:39:17 PM
Broken
Status: offline
This should get you up and running-
http://www.tompierce.net/190/html/paint/glassing.htm
http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/finishing_techniques/apply_fiberglass_finish/index.htm
I think I will do one more flight!!!!
(in reply to 7aso)
       Post #: 2
RE: Glassing a warbird for the first time - 8/28/2007 4:17:53 PM
Skyflying1
Status: offline
Here's another link to give some ideas: http://www.rc-tech.net/fiber/fiber.htm
(in reply to Broken)
       Post #: 3
RE: Glassing a warbird for the first time - 8/28/2007 5:14:51 PM
7aso
Status: offline
Those were by far the best guides I've ever read. Thank you!
Warbirds or nothing
(in reply to Skyflying1)
       Post #: 4
RE: Glassing a warbird for the first time - 8/28/2007 6:57:17 PM
Evil_Merlin
Status: offline
Hrm, one guy says to NEVER thin your epoxy, one guy says 50/50 mix... I wonder who is more correct.
(in reply to 7aso)
       Post #: 5
RE: Glassing a warbird for the first time - 8/28/2007 7:42:09 PM
BobH
Status: online
I can't say for sure who's corret but I've glassed many planes and never thinned the finishing epoxy. I don't think its necessary.
I have been using a small roller though and it does make a lot of difference in the effort and finish. You can buy cheap short foam rollers at Home Depot etc. They put on the resin just like you would put on paint.. Very efficent and even with little sanding in between. Try it.. you'll like it.
BobH.
(in reply to Evil_Merlin)
       Post #: 6
RE: Glassing a warbird for the first time - 8/28/2007 8:41:30 PM
Steve Collins
Status: offline
Using the correct epoxy, there is no need to thin it. The Z-Poxy is good stuff as it is. I have used Z-Poxy a lot and I also use West System epoxy for glassing.
Once you are done with the glassing, you will realize that the hardest part of the process was getting started.
The downside to covering the whole plane in one session is that you cannot set it down anywhere until the epoxy cures. If you have the fuse on a stand like the type that connects to the motor mount and rotates around, there is no reason why you can't cover it all in one session. Cover the wing on one side one day and cover it on the other side the next day. Same goes for the control surfaces that should be glassed before they are permanently attached.
Steve Collins
(in reply to BobH)
       Post #: 7
RE: Glassing a warbird for the first time - 8/28/2007 8:45:09 PM
Edwin
Status: offline
I dont thin finish reson. But I do thin epoxy. Both have worked ok for me. I find the finish reson to give a little firmer part. Epoxy is slightly more flexible which works pretty good for cowls and making parts. When glassing a wood fuse or wing I like to have it pretty thin for spreading. One coat does it for me. Then I use a light weight filler for the weave.
Edwin
(in reply to BobH)
       Post #: 8
RE: Glassing a warbird for the first time - 8/28/2007 8:57:13 PM
7aso
Status: offline
I am having an impossible time trying to find an aluminum paint that is fuel proof. I've been searching the forum for hours and I keep running into dead ends.
I heard Rustoleom is fuel proof but not their aluminum. Same goes for Krylon.
Warbirds or nothing
(in reply to Edwin)
       Post #: 9
RE: Glassing a warbird for the first time - 8/28/2007 9:43:01 PM
BobH
Status: online
You can "fuel proof" paint buy over coating it with clear (either glossy or satin finish) from Nelson's paints. An additive makes his clear fuel proof and since it's water base it goes over every things.
http://www.nelsonhobby.com/paint.html
BobH.
(in reply to 7aso)
       Post #: 10
RE: Glassing a warbird for the first time - 8/28/2007 11:21:22 PM
7aso
Status: offline
quote:
ORIGINAL: BobH
Through my forum searches, I read that fuel proofing Krylon or Rostoleum makes them loose their shine, but I will look into Nelson's paints.
Quick question: my wing fairings are plastic. Do I have to glass those too or should I just apply primer to them?
Warbirds or nothing
(in reply to BobH)
       Post #: 11
RE: Glassing a warbird for the first time - 8/29/2007 12:50:49 AM
BobH
Status: online
Do yourself a favor and use a decent paint. I wouldnt recommend krylon or rustoleum paint. If you are going through the trouble of building and glassing your plane then use a decent paint too. You'll be more than glad you did.. In stead of those to paints I'd opt for Latex paint thinned and sprayed. My preference would be to use Warbird paints or Nelson's or Klass Kote. Any one of those three will serve you well.
You don't have to glass the fairings but you can.
BobH.
(in reply to 7aso)
       Post #: 12
RE: Glassing a warbird for the first time - 8/29/2007 1:45:55 AM
7aso
Status: offline
quote:
ORIGINAL: BobH
How would I go about getting the aluminum look with warbardpaints.com? I didn't see it being offered. Closest I found was Dark Grey..
This is the exact paint scheme I'm going for:
Warbirds or nothing
(in reply to BobH)
       Post #: 13
RE: Glassing a warbird for the first time - 8/29/2007 2:09:39 AM
BobH
Status: online
Ok for that "paint scheme" you really need to use Flite Metal. It's real aluminum not paint. I don't think there is any paint that will yield a polished aluminum surface.
BobH.
(in reply to 7aso)
       Post #: 14
RE: Glassing a warbird for the first time - 8/29/2007 3:18:00 AM
7aso
Status: offline
What color do you think on warbirdpaint.com would come close to that look? I really want to glass it and paint it rather than use flite metal. If I can come close I would be happy.
Warbirds or nothing
(in reply to BobH)
       Post #: 15
RE: Glassing a warbird for the first time - 8/29/2007 4:54:09 AM
bigtim
Status: offline
here's a suggestion it may or may not work for you but its something I have been using for parts I want to look like aluminum.
it's a paint called Modern Masters the paint is water based and has metalic particles in it the color I have been using is ME-150 SILVER(OPAQUE).
it looks really nice and sprays out well I haven't done any fuel testing on it because I have been clear coating with www.warbirdcolors.com paint.
I got it from the local Benjamin Moore paint store where I get my supplies for work,I am a finish carpenter and painter,but when sprayed it gives a smooth alum. finish it also brushes out pretty well also.
these days I have been working with water based paint almost exclusively my lungs and family appreciate it, I have been pleasantly surprised with the results, the WBColors is a nice product I am quite pleased with the results I am getting with it.
< Message edited by bigtim -- 8/29/2007 4:56:44 AM >
(in reply to 7aso)
       Post #: 16
RE: Glassing a warbird for the first time - 8/29/2007 1:27:35 PM
BobH
Status: online
Take a look here:
http://www.mustangsmustangs.net/p-51/survivors/pages/45-11507.shtml
That page shows the original and the restored plane. Quite a difference I think. You can reproduce the original scheme using paint more closely than the restored (very shiney) plane. Although I haven't used it Behr aluminum latex paint is supposed to yield a very good look.
bigtim might have some other paints worth looking into also.
Oh one more thing.. on the original Mustangs the wings were painted aluminun unlike the Fuse which was left natural aluminum (on some planes).
< Message edited by BobH -- 8/29/2007 1:33:19 PM >
BobH.
(in reply to 7aso)
