bob27s
OH, USA Status: online
For the Sport Jett engines, you do not want to run a pump or regulator system. Others have had decent success with ST, OS and other engines when using pumps or pressure regulated devices. In genernal, the CG change with the tank in the stock location is not critical. That is true for the Toni. If you are flying pattern, yeah.. it sometimes matters. For sport flying, its not worth affecting or complicating engine/fuel system performance for a .15" shift in CG. If CG tank placement is a personal preference, then so be it, and nothing wrong with that. After flying r/c for 30+ years, a pump-regulates system and CG located tank has been something I've found was necessary maybe a handful of times. And that was on the OS/Hanno pumpers and the YS engines - since it was inherent. More recent years, using the bubble-free fuel systems has provided some flexibility in tank location and position without need for more than just muffler pressure.
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
