HerrSavage
Joined: 9/17/2005 From: Leipzig, , GERMANY Status: offline
So far the brakes do suck.. Which Craddocks do I need exactly - and where has them?? Isn't Amain all sold out??.. Here in Germany people are talking about some other brand - can't remember right now what it's called... Anyway, I fixed my servo problem - I think.. I threadlocked the screw into the servo, so I hope that works.. Then, I went out to run the rest of yesterday's fuel out of it, and try to fine-tune it some more, and the front right wheel went all squirelly. I thought great, just like all the German guys here busting their carriers.. But it wasn't that - the bottom screw holding the hub on had come out(in the grass - C ya..) So, went home, and fixed it.. The CNC screw threads were kind of stripped though(****??) - all I could do was take a thinner shim instead of the washer, and lock-tite it in - which I did.. Took everything back out, and then the turnbuckle - front right - popped off.. So I thread-locked that.. Then I looked everything over - and saw the screw holding the servo steering arm was coming out.. ****?? So I went and redid the whole linkage, and threadlocked THAT screw in as well.. I wish I would've just gotten Futaba servos to start with.. For whatever reason, it's impossible to find the right Hitec-size screw (I think they're 2.6mm, but all you can find here is 2.5...) It was even hard back when I put it together finding a good servo-arm for it.. I love my 5955's..., but jeeze... On another note, I would like to try a bit more offset on the tires. I recently bought a set of LPR's, but they're non-offset. I don't want to spend €35 on the 10mm extenders, so my question is: for racing, which would be better??: Spend €50 on either a set of 8T wheels or GRP Cubics, OR just dump the 35 bucks for the extenders?? There's a nice looking set of cheaper extenders on e-bay here, but I was told the pins on the Hyper have a weird size...
< Message edited by PatrickBW -- 6/23/2008 7:31:39 PM >
