RE: the hyper st PRO thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: the hyper st PRO thread!
Page: <<   < prev  55 56 [57] 58 59 60 61 62 63 64   next >   >>
Login
RE: ... - 9/6/2008 3:04:44 AM
busta774
Status: offline
hey im neally finish building my hyper st pro and just wondering what parts should i look out for whats the most common part breaking on these, and i must say this truggy is nice cant wait to get it running.
_____________________________
Hyper 7 PBS Pro:Mach21, Spektrum,
(in reply to Oasis TR)
       Post #: 1401
RE: ... - 9/6/2008 4:49:28 AM
spikeitaudi
Status: offline
Watch out for the fuel tank posts (which crack easily), king pins (tend to back out), and potentially leaky diffs (easily fixable with Kyosho Diff Gaskets). Other then that run it and have a blast. Be sure to post pics. I remember the days when it was brand spanking new.
Hyper ST PRO w/OS 21VZ-B V-Spec, Kyosho SP2 Electric Conversion, Team Losi Micro-T, Traxxas Slash
MARBETH Nitro Sports
(in reply to busta774)
       Post #: 1402
RE: ... - 9/6/2008 7:23:03 AM
HerrSavage
Status: offline
The main thing to watch out for based on my experience would be the front knuckles.. Make ONE THOUSAND PERCENT sure your steering linkage and then radio settings are PERFECT.. And don't forget to threadlock the screws.. MANY people here in Germany anyway have had problems with those screws into the knuckles stripping out, or just outright breaking them..
(in reply to spikeitaudi)
       Post #: 1403
RE: ... - 9/7/2008 12:53:35 PM
busta774
Status: offline
yep ive thread locked every where ive built buggies and truggy before well when i find my camera cord ill post pics of while its still shiny im up to putting all the throttle/brake linkages on.
Justin
(in reply to HerrSavage)
       Post #: 1404
RE: ... - 9/8/2008 1:33:50 AM
j_blaze
Status: offline
just want to clarify that the kyosho diff gaskets are the ones to use. i've been using the ofna/jammin ones with inconsistent results and blown gears.
CASTER K8T Pro - GO 21 R-Spec JR, DX3R
Caster Zx1-R - Caster MKII 215t, Bron''s GEN2
       Post #: 1405
RE: ... - 9/8/2008 1:40:56 AM
spikeitaudi
Status: offline
quote:
ORIGINAL: j_blaze
J-blaze, you took my advise and tried the Kyosho ones I take it. Have they worked out for you?
(in reply to j_blaze)
       Post #: 1406
RE: ... - 9/9/2008 1:36:39 AM
j_blaze
Status: offline
not yet, i ordered 2 sets though. i was using the ofna/jammin ones which are about 1mm too big/ they work for a while but i'm going through gears in the diffs like crazy, no leaks tho. i check mesh, fill to the right spot, check mesh again, used longer screws even. every gallon or so one of my diffs blows one of the large internal gears, just flat. this last weekend it was the rear during qualifying then the center went at the start of the main. i'm gonna redo all 3 for this weekend to test, then rcpro race in 3 weeks. woohoo. i'm gonna do some lightening this time on the st, cf shock towers, turnbuckle chassis braces, hyper 7 front upper mount. we'll see how it goes.
       Post #: 1407
RE: ... - 9/9/2008 2:08:26 AM
spikeitaudi
Status: offline
quote:
ORIGINAL: j_blaze
Sorry to hear that. Your blowing diffs to quickly. If you blew the center also, the kyosho gasket won't help for that one. Wierd. This has been my first season on my Hyper. Haven't blown any diffs yet. And I have been hard on my hyper.
       Post #: 1408
RE: ... - 9/9/2008 2:48:25 AM
darksoul242001
Status: offline
quote:
ORIGINAL: redsteal92
hi i have a question too, i still have the standard flywheel but with the standard one i cant use a bump start because it's to small do you guys know a bigger one that will fit and start with a bumpstart?
I'm currently using a kyosho 34mm flywheel. I know that you can use the one from the Hyper 7 buggy. It depends on the starter box too. I was using a dynamite starter box before I went to the ofna truggy starter box. Now I have no issues starting anything. You can also use a flywheel from a Savage X too and its way cheaper! When using the kyosho or the savage X flywheel I was able to start the truck with my old starter box. Hope this helps.
Hyper ST Pro / Picco P3 .28
Jammin Crt .5 / Picco .12 7-port
(in reply to redsteal92)
       Post #: 1409
RE: ... - 9/13/2008 8:44:33 PM
j_blaze
Status: offline
yeehaw!! i finished my hyper st lightening and it is crazy. i got some cf hyper 7 shock towers on ebay for like $30 and then used hyper 7 chassis races and front upper mount assembly. i took out the shock towers, braces and center brace (also lowered center diff for better mesh). i haven't weighed it yet but performance wise it ran like a deer on crack today. i burned up a servo but i'm going back out today.
(in reply to darksoul242001)
       Post #: 1410
RE: ... - 9/14/2008 3:23:05 AM
spikeitaudi
Status: offline
J_blaze,
We need pics.
       Post #: 1411
RE: ... - 9/14/2008 3:32:28 AM
j_blaze
Status: offline
i'll post pics tomorrow, with the hyper and a trophy nah, just a club race. the changes make this go 3pt look like one of the old ninjas. i also am going to gear up another tooth on the clutchbell cause 13/46 is too much at the bottom, i'll try 14/46 see how it goes.
       Post #: 1412
RE: ... - 9/14/2008 3:54:11 AM
spikeitaudi
Status: offline
If you could include parts number that would be great.
       Post #: 1413
RE: ... - 9/14/2008 10:02:07 PM
