PZ T28 trojan Brushless
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> PZ T28 trojan Brushless
Page: [1]
Login
PZ T28 trojan Brushless - 8/29/2007 3:59:08 AM
Dragonfueled
Status: offline
HI guys I was lookiing into the Parkzone T28 trojan to upgrade from my old PZ J3 cub. Its either that or get the new Brushless J3. Do you guys think it will be to much of a jump and will the T28 be a typical warbird and hard to fly?
_____________________________
3.3 revo
brushless stampede
       Post #: 1
RE: PZ T28 trojan Brushless - 8/29/2007 4:54:02 PM
Bigtone
Status: offline
Hey Dragonfueled, this may help you out!
http://www.rcuniverse.com/forum/m_5709888/mpage_1/key_/tm.htm
www.myspace.com/airshows
(in reply to Dragonfueled)
       Post #: 2
RE: PZ T28 trojan Brushless - 8/30/2007 3:42:17 PM
Leo L
Status: offline
Dragonfueled,
It all depends on what you want to do. If you love flying your J3 and simply want to get a boost in its performance, but don't want to get into flying with ailerons, then get the brushless J3. Keep in mind that it will need the same tailwheel / front wheel mods that the original needed to keep it from doing ground-loops. The Trojan will probably be harder to fly than a high wing 4-channel trainer like the Minimag or the E-Starter, but should be easier to fly than the warbirds like the Mustang, FW or Spitfire. Only you know how quickly you adjust and react to different situations. If you want an easy step up, go with the Minimag or E-Starter first, and then the Trojan. If you feel confident to take a fairly large step, go straight for the Trojan.
(in reply to Bigtone)
       Post #: 3
RE: PZ T28 trojan Brushless - 1/23/2008 1:54:54 AM
thefig781
Status: offline
I've had my Parkzone T-28 Trojan for about 6 weeks and I love it! Very stable and the performance is more than I had hoped for. It doen't have unlimited veritcal capability ( yet )... but is very stable and forgiving. It doesn't have a tendancy to snap roll if you get it too slow, it just drops the nose a bit and then levels out. Spins are a blast, and just releasing the controls stops the spin and a little elevator and it makes you look like a pro.
I did change the receiver, and put in a Spektrum 2.4 Ghz AR-7000 because of planned mods. The nice part is that in a tight turn is doen't have a tendancy to drop the nose like so many other warbirds do. I've added flaps and I have a different ( read, more powerful AXI 2814 ) motor on order and it is supposed to be equivalent to a .22 - .25 two stroke nitro. Can't wait to see what it'll do in a vertical climb! Waiting for warmer weather so I can check out the operation of the flaps, it should really float in for a landing. Would I recommend it for a first trainer....No; not unless there was an instructor on a buddy box. Can you learn to fly using the T-28 as a trainer with a buddy box, YES, most deffinately. For a sport plane it would make an outstanding "sport trainer". But not for a first time pilot.
Enjoy,
Jim
(in reply to Leo L)
       Post #: 4
RE: PZ T28 trojan Brushless - 5/8/2008 2:39:40 AM
pauldutt
Status: offline
This may be the wrong place to post this but I have a PZ T28 and I love it. It lands pretty hot though. I see a few people have modified their T28s with flaps to slow it down. I'm running a Spektrum DX6i system and was wondering if anyone has tried to set up their radio for flaperons? I did but I'm afraid to fly it. But I don't want to cut up my wing either unless I absolutely have to. Call me chicken.
       Post #: 5
RE: PZ T28 trojan Brushless - 5/8/2008 11:57:36 AM
tubamike78
Status: offline
that's how i have mine set up. just program about 7-10" up elevator in it alos. just try it up high a few times to get the feel for it before landing.
good luck
(in reply to pauldutt)
       Post #: 6
RE: PZ T28 trojan Brushless - 5/8/2008 6:05:42 PM
pauldutt
Status: offline
I don't understand what you mean by programming 7-10 deg up elevator in the FLAPERON setup. Where do I do that?
(in reply to tubamike78)
       Post #: 7
RE: PZ T28 trojan Brushless - 5/8/2008 10:15:01 PM
tubamike78
Status: offline
this is done in the flaps menu, it has 2 listings, one for nornal, one for land. this is where you want to set about 10 deg up elevator in.
       Post #: 8
RE: PZ T28 trojan Brushless - 5/9/2008 2:58:13 AM
pauldutt
Status: offline
Thanks. I was confused by the 7-10 deg UP comment because I thought I had the T28 programmed into my DX6i. I had it programmed into my DX6 instead (I have too many airplanes) and the DX6 doesn't have that menu. I'll program my DX6i and try it. Thanks again.
       Post #: 9
RE: PZ T28 trojan Brushless - 5/12/2008 4:44:49 AM
pauldutt
Status: offline
I couldn't get the DX6i to program properly (WINGTAILMIX - DUALAILE). The flaps work but the ailerons were operating in reverse. I worked on it for hours and did everything both by the manual and experimenting to no avail. I went back to the my DX6 (MIX - FLP - ON) and everything appears to operate as specified. Now I just have to work up the courage to fly it.
Thanks again
       Post #: 10
RE: PZ T28 trojan Brushless - 5/12/2008 11:50:26 AM
tubamike78
Status: offline
did you try reversing the ailerons?
       Post #: 11
RE: PZ T28 trojan Brushless - 5/12/2008 11:02:32 PM
pauldutt
Status: offline
I tried everything. I have the same radio setup in my mini Edge 540 and everything works as advertised on it. No matter what I do to the Trojan in the dual aileron mode (WINGTAILMIX), the ailerons are backwards. The only thing I noticed that is different between the 540 and the Trojan is the aileron servo control arms are on opposite sides. I'll have to see how it works on the 540 before I mess with the Trojan flaps anymore. I give up.
       Post #: 12
RE: PZ T28 trojan Brushless - 5/23/2008 2:33:31 AM
cjg
Status: offline
Mine were backwards with the DX6i, simply reversed the channels and worked find.
You must have something set wrong as the DX6i with dual ailerons worked great on my T-28. I have mine set for spoilerons rather than flaperons, but same principle.
BX, XXXT, MQ, RC18MT, Rustler; BCX, SuperCub, T-28 Trojan, DX6i
www.usd.edu/~cgutzman/evader; www.usd.edu/~cgutzman/mq
       Post #: 13
RE: PZ T28 trojan Brushless - 5/23/2008 3:28:15 AM
pauldutt
Status: offline
What do you mean by "simply reversed the channels"?
I reversed left and right servo leads (Rt to Aux- Lt to Aile) on receiver and also tried programming the DX6i aileron reversing. The ailerons worked either backwards or they both moved up & down together when I engaged the FLAP switch.
They work okay with the DX6 transmitter but not with the DX6i. I'm using an AR6100 receiver. I have other issues with the DX6 transmitter so I don't use it anymore.
(in reply to cjg)
       Post #: 14
RE: PZ T28 trojan Brushless - 6/27/2008 2:38:47 AM
RCSUPERCUB
Status: offline
I just bought this plane today brought it home and plugged in the battery to test the motor to what it was like and i get this awfull loud vilent vibration form the motor, when in full power it does this and i can see the nose is moving around a bit, so i took it back to the hobby shop and got them to look at it, they took it all apart and all was
