cwhite
MO, USA Status: offline
Oops, I ran one tank on the ground, about 8 oz. at a time. I kept the throttle low and I didn't hold it wide open. I got to maiden the plane today and got a total of 6 flights on her. At 26lbs and motor still new it had great pull out. Plane flew great. Harriers and hovers are fairly solid. Feels like its still a little nose heavy in a hover, nose wants to fall to the side slightly but not too bad. I was comfortable enough to get some pictures taken by a club member with the tail about 1' off of the ground. Blenders and inverted flat spins are great. upright flat spin is not as good as inverted for me. Just touch the rudder for knife edge. Rolling harriers on the first flight, they are very easy with this plane. Mine falls a little when inverted but just slightly. Lands great and looks great on the flight line. Good design guys! My setup: DA85 Slimline muffler Ignition Battery - 4.8v Ellite 2000mah NiMH Receiver Batteries - (2) 6v Ellite 2000mah NiMH Receiver - JR R921 with 2 remote recievers JR8711 for rudder Hitec HS5955's for elevators and ailerons Hitec HS5945 for throttle Chris
