RE: Kimball-Somenzini Python Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Kimball-Somenzini Python Build Thread
Page: <<   < prev  28 29 30 31 32 33 34 35 [36] 37   next >   >>
Login
RE: Kimball-Somenzini Python Build Thread - 5/7/2008 6:55:22 AM
flatlandmike
Status: offline
forgive my mistyping of my thought. Make the plane more nose heavy ... fill in the rest
< Message edited by flatlandmike -- 5/7/2008 6:56:29 AM >
_____________________________
www.jerseymodeler.com
Special thanx to The Crew Mike B. Jim Z. Ed J. Jim S.
(in reply to Hooked-On-RC)
       Post #: 876
RE: Kimball-Somenzini Python Build Thread - 5/7/2008 5:55:55 PM
zzw26n
Status: offline
quote:
ORIGINAL: KJKimball
As soon as I have it dressed out, I will post some shots for you guys. I am having the graphics made by the same guy that made the full size python graphics for me.
Kevin
Mr. Kimball,
Order two sets of Graphics, Please! I'll buy the second set, pay for shipping, etc.
Ward
(in reply to KJKimball)
       Post #: 877
RE: Kimball-Somenzini Python Build Thread - 5/7/2008 10:49:29 PM
KJKimball
Status: offline
Ward,
I should have them tomorrow so I can get them on for Joe Nall. I don't know the price yet so I think it is better to wait and see what they run. I will let you know once I have them.
Kevin
(in reply to zzw26n)
       Post #: 878
RE: Kimball-Somenzini Python Build Thread - 5/7/2008 11:35:11 PM
zzw26n
Status: offline
quote:
ORIGINAL: KJKimball
Ward,
Kevin
Thanks Kevin ......... I have time, no rush.
       Post #: 879
RE: Kimball-Somenzini Python Build Thread - 5/11/2008 5:40:14 AM
dickie boy
Status: offline
I've played with cg a bit and mine pulls toward the gear regardless. The slower your doing knife edge the more elevator needed. I ended up using a five point curve to get it right for different speeds. It's pretty much hands off now on knife edge. Just assign your mixing for a couple of flight modes and then turn it off for your 3d mode. I've got close to a hundred flights on mine and almost have it perfect now. It's hard to spend the time mixing, once you get it in the air all you want to do is tear up the sky instead of doing set up.
       Post #: 880
RE: Kimball-Somenzini Python Build Thread - 5/19/2008 4:27:56 PM
JIMMYTHEEAGLE
Status: offline
Well I think I had the first shipped python last fall and probably out of all those shipped in the first group, mine is probably the last to fly. I flew the first three flights last night and it was worth the wait. I've had 3-4 biplanes in my lifetime and none of them were good for precision. QuiQue said that this plane presents well, snaps well and flys straight. He is absolutely correct. This plane will fly all the IMAC sequences and present very well to the judges. I have to now decide if I will practice and compete with the python or my 40 percent carden extra. So far what I like most for precision flying is the snaps that stop on a dime, half rolls that are quick and precise and rolling circles are so easy I found my self way ahead of 4 rolls per circle that I had to slow everything down in my head. Also, one roll per circle is very easy with this plane.
My set-up is a little different from previous posts so I will list it. DA 100 on cannisters no surprises there. I'm still coming on and off the cannisters at low idle so a have a little fiddling to do with the needles. I'm using two DMS2 7 channel receivers with fromeco battery, regulator and switch on each one. One receiver has left and right lower ailerons, left elevator and one of two rudder servos on a swb pulley dual servo tray. Other receiver has throttle both upper wing ailerons and right elevator and the second rudder servo. Three flights yesterday and some range checking for a total of 39 minutes and my batteries under load went from a starting voltage of 8.03 to 7.88 and the other battery at 7.92. Looks like I could fly for a week Need to cut some graphics for it now it it will be ready for the season.
I did some 3D on two of the flights. My low needle setting is a little off so I was either underpowered or overpowered for torque rolls but it is very easy to find the point at which it starts to rotate and hold it. Rolling harriers are awesome and you can do 4 point rolls in high alpha very easily. I did the slowest high alpha knife edge ever first time and then applied power and did 3/4 of a knife edge loop. I bailed out on the last quarter(Hey it's a new plane!) but I'm sure it would have pulled through. I'm looking forward to getting things dialed in. I would like to switch to the 12X radio when it comes in for the 3rd rate. I'm a little nose heavy and I would like a 3rd rate for landing to have a little extra elevator. With two rates I have a precision rate and a 3D rate. I'm landing a little hot now because I don't want to run out of elevator. Jim
(in reply to dickie boy)
       Post #: 881
RE: Kimball-Somenzini Python Build Thread - 5/19/2008 5:55:22 PM
zzw26n
Status: offline
Nice write-up Jim! looking forward to mine.
quote:
ORIGINAL: JIMMYTHEEAGLE
(in reply to JIMMYTHEEAGLE)
       Post #: 882
RE: Kimball-Somenzini Python Build Thread - 5/27/2008 1:58:53 PM
JIMMYTHEEAGLE
Status: offline
I know have 9 flights on mine and all is going well. Having some tuning issues with the cannisters that I installed and wondered if anyone had some suggestions or similar problems. Using DA 100 that was new last spring. Flew last year on standard mufflers with no issues. Using new fuel this spring and running a second DA 100 on mufflers and it is running fine. Basically, with the cannisters it is changing sound or pitch on 45 degree uplines. When slowed down to 3D idle, it seems like it's loading up almost to the point it wants to die so it's limited my time at low speeds. It never has died yet and every landing the motor has continued running. After switching to the cannisters the first thing I noticed is that the high end needle had to be leaned as the the motor wouldn't reach full power. I've also been leaning the low needle(three times now) and neither the low idle or the pitch changes in transition are getting any better. Is it normal to lean both needles when going to cannisters? I'm guessing these are KS, (ordered from DA) and they match the cannisters in the installation pictures on the QQ Pitts assembly manual. They're installed exactly per these instructions. Any help would be appreciated. thanks, Jim
       Post #: 883
RE: Kimball-Somenzini Python Build Thread - 6/2/2008 8:57:12 PM
ArmandD
Status: offline
Hi guys. I have been flying my Python like crazy since about March. I have about 10 gallons through it already!
I am uploading some pics for you to check out. Notice that I filled in the bottom of the plane...
Armand
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ArmandD -- 6/2/2008 9:09:31 PM >
       Post #: 884
RE: Kimball-Somenzini Python Build Thread - 6/9/2008 1:05:00 AM
Rezagh
Status: offline
Jim,
Cannisters in the manual are MTW75. What is your needle setting on the low end?
Armand great pics
Reza
Quique's Aircraft Company
(in reply to ArmandD)
       Post #: 885
RE: Kimball-Somenzini Python Build Thread - 6/9/2008 1:06:25 AM
Rezagh
Status: offline
VIDEO
Guys,
I was invited to do a demo flight at one of our local clubs that has over 400 members. This was Scale Squadron of Southern California event. This happened yesterday 06-08-08. Here's the link directly to the video www.RCModelAviator.com/Videos/ScaleSquadronFunFly.wmv or you can go to my website www.RCModelAviator.com and select the video under Videos button. This event was great. Many attendance and was run very smooth.
It was windy but plane did great. Hope you enjoy it some.
Reza
(in reply to Rezagh)
       Post #: 886
RE: Kimball-Somenzini Python Build Thread - 6/9/2008 2:49:19 PM
JIMMYTHEEAGLE
Status: offline
Reza,
I'm just inside of 1 3/8 on the low and still 1 1/2 on the high. I'm having a very hard time getting a good engine sound on the low end. It sound like it's loading up when I bring the throttle to idle or just above and I start into rolling harriers. After a couple of revolutions the motor is running rough and power has dropped off. 2-3 clicks of increase throttle brings the motor out but then the engine rpm is too high to continue with the rolling circles. I did put on a carb plate but that had zero improvement. I'm going to change out the plugs and disassemble the carb to look for any stray debris. There just isn't any reason for the motor to run this way. I bought the headers and pipes that are recommended for the plane, installed correctly and the motor ran great all last year on standard mufflers before I removed it and put it in the python. I either have an issue with the carb drawing fuel internally or with my engine baffling tht I installed I've created some type of air pressure void that is pulling fuel out of the carb. On 45 degree uplines and the correct lighting you can see a thin, white vapor trail leaving the plane which must be unburnt fuel leaving the carb. The plywood ring that runs along the bottom of the cowl is damp and stained at the bottom of the cowl from the fuel leaving the carb. I'm tempted to just remove the upper and lower baffle plates that I installed and let the air rush under the motor. I'm curious if there are any python flyers that are using the cans and also baffled the engine for cooling. Thanks, Jim
       Post #: 887
RE: Kimball-Somenzini Python Build Thread - 6/9/2008 6:14:38 PM
