RE: Kimball-Somenzini Python Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes CAP 232 - 27% - RTF
Seller:  nwyninegar
Details:   $1,200.00   |  10/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Kimball-Somenzini Python Build Thread
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 5:39:01 AM
Rezagh
Status: offline
Let me ask you guys this. In what order do you prefer building your airplane. i.e getting hinging done first, mounting landing gear second,... I have been doing this in certain orders and that's how I have written all my assembly manuals but modelers tend to make their own orders. I would like to ask you to list them for me from your perspective. At the end I will get a combination of all and write the manual in the order that is closest to what most modelers would do.
I would appreciate your inputs on this.
Reza
_____________________________
Quique's Aircraft Company
(in reply to Rezagh)
       Post #: 76
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 7:21:55 AM
marc 540
Status: offline
Hi Reza,
The first thing I like to do is get it up on it's own leg's to get the weight off the fuse bottom. Then the stab's, prep the wing's. Then do all the hinging and control horn's. After that I'll install the engine/cowl and canopy. The last thing I like to do is the radio install and setup. This is of course a very brief and non-detailed description.
Marc 540
       Post #: 77
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 7:47:44 AM
marc 540
Status: offline
Japan3d,
Any chance of posting a bigger picture of your avitar? Look's very interesting!!
Marc 540
(in reply to marc 540)
       Post #: 78
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 8:14:03 AM
Rob Howarth
Status: offline
Rezagh,
Scale scheme for me then - I am out in Apple Valley CA in mid October, what are the chances of having one sent to me there and I'll get it back to the UK?
With regards to the build manual, most guys buying/building one of these are pretty experienced and will probably have their own sequence to work to.
Rob
       Post #: 79
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 8:35:39 AM
Rob Howarth
Status: offline
Kevin,
I've sent you an email.
Rob
< Message edited by Rob Howarth -- 9/7/2007 8:36:00 AM >
(in reply to KJKimball)
       Post #: 80
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 12:26:48 PM
japan3d
Status: offline
Here you go Marc
Click to see fullsize image.
Click for fullsize
< Message edited by japan3d -- 9/7/2007 12:27:26 PM >
"http://www.giantscaleinjapan.com/index.html"
(in reply to Rob Howarth)
       Post #: 81
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 12:55:56 PM
randy racer
Status: online
reza it was the outer bolt.
the first thing i do is go over all covering with a heat gun and iron the install the landing gear to get the fuse up off of the table, then i do the hinging and so on.
thanks japan3d, is that your pit crew?
randy racer
Revver Bro #196
Ford RV Refrigeration Training Center & The RVRN
(in reply to japan3d)
       Post #: 82
RE: Kimball-Somenzini Python Build Thread - 9/7/2007 10:51:14 PM
Rezagh
Status: offline
Makes total sense. The outer bolt is longer and higher bending moment on the bolt!
Thank you,
Reza
quote:
ORIGINAL: randy racer
randy racer
(in reply to randy racer)
       Post #: 83
RE: Kimball-Somenzini Python Build Thread - 9/8/2007 12:28:48 AM
turboratt
Status: offline
hey reza same her get it on its own legs first then tail and hinges
       Post #: 84
RE: Kimball-Somenzini Python Build Thread - 9/8/2007 2:43:55 AM
shakes268
Status: offline
Same for me. I like to get the gear on first that way if I have to move it, the fuselage can stand on its own.
(in reply to turboratt)
       Post #: 85
RE: Kimball-Somenzini Python Build Thread - 9/8/2007 4:54:23 AM
octanehuffer
Status: online
I install the engine first, then uninstall. Assemble the feathers. And lastly install the landing gear. I have tall work benches and with the gear on the plane I cant see inside too well. Having the gear on also creates an obsticale for me. If its flat on the table it makes it easier for me. Regardless of the instruction manual steps I build with my own process.
Adam
QQ 120" Yak, QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, H9 T-Craft G-26, etc
(in reply to shakes268)
       Post #: 86
RE: Kimball-Somenzini Python Build Thread - 9/8/2007 8:34:31 PM
Rezagh
Status: offline
Great input guys. Thank you very much!
(in reply to octanehuffer)
       Post #: 87
RE: Kimball-Somenzini Python Build Thread - 9/8/2007 8:38:57 PM
Rezagh
Status: offline
Hinging Rudder and Gluing Vertical Fin:
Before hinging the rudder, we need to trim the vertical fin so we have a very good bond with fuse. To do this you can gently dry fit the rudder to fuse but DO NOT put exccesive force there as it is a very tight fit and with ultracote on rudder it would be really hard to fit the rudder to fuse!
Please see the picture of where roughly you need to remove the covering. You can remove on the conservative side and then dry fit and draw the line. Leave about 1/8" of covering and make sure to iron it down so it is tight and stretched!
OK now let's hinge the rudder. It is no different than hinging other parts. Just clean the glue that oozes out from the Stick like part of rudder that goes in the fuse.
After hinging is done and glue is set apply 30 minute epoxy or Elmer's glue. I didn't have 30 min epoxy so I went by Elmer's glue. It takes more time to set but very easy to work with and it gives you plenty of time besides it is really easy to wipe the excess glue with a dampened towel.
If you used Elmer's glue make sure that you do not accidentally move the rudder. Actually it would be really hard to do so because it is a very tight fit connection.
I used a mixing cup and brush to make sure I apply glue everywhere.
Please let me know if you have any questions. Hopefully pictures will explain better than I did.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Rezagh -- 9/8/2007 11:23:21 PM >
