katana 40 freestyle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> katana 40 freestyle
Page: [1]
Login
katana 40 freestyle - 8/29/2007 1:36:06 PM
Bxtreme aviator
Status: offline
hi guys
im lookin at the katana 40 size freestyle. what is the smallest engine to use?
bxtreme aviator
       Post #: 1
RE: katana 40 freestyle - 8/29/2007 6:02:50 PM
w8ye
Status: offline
We don't know what brands you have available to you? We also do not know your desired flying style?
For just general sport puttering around a good 40 two stroke will do the honors
If you like and expect 3D you should have as a minimum a ASP/Magnum XLS52 two stroke or maybe the new OS 55AX two stroke?
In the four strokes and 3D you should have at least a 70 or bigger size four stroke.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Bxtreme aviator)
       Post #: 2
RE: katana 40 freestyle - 8/29/2007 11:07:09 PM
Gregor32
Status: online
if this is the katana you have , i run a magnum 70 4st with mas k series 13x6 and the performance is good. it will hover at a little over half throttle with enough power to pull out safely. this is the esm katana 40 and a lot of fun to fly. some people ive heard are running 90 size motors in it.
Cheers Greg
Click to see fullsize image.
Click for fullsize
(in reply to w8ye)
       Post #: 3
RE: katana 40 freestyle - 8/30/2007 7:51:35 AM
Bxtreme aviator
Status: offline
Thanks guys i spoke to my instructer who owns the local hobby shop and has a ASP 52 size there and its even cheaper then the OS 46 so i will go for the ASP .
cheers jp
(in reply to Gregor32)
       Post #: 4
RE: katana 40 freestyle - 11/7/2007 11:33:18 AM
Bxtreme aviator
Status: offline
hi
i had problems with the cg (center of gravity) it was xtrmly tail heavy did any of you have the same problems?
thanx jp
       Post #: 5
RE: katana 40 freestyle - 5/10/2008 7:50:44 AM
freeair
Status: offline
quote:
ORIGINAL: Bxtreme aviator
cheers jp
the ASP engine may be cheaper and just slightly larger in cc,s but i will say the OS will last alot longer.
       Post #: 6
RE: katana 40 freestyle - 5/10/2008 8:27:11 AM
XJet
Status: offline
The ASP is a lot more finicky to set up the low-end needle is ultra-sensitive and needs careful adjustment but it's a stump-puller compared to the OS46.
However, the OS46 is a far better-made engine. Little things like the use of a single pinch-bolt retainer for the carby rather than the two threaded bolts in the ASP and the better quality muffler mean the OS will probably be less hassle and trouble in the long-run.
If I were you I'd go hunt down a TT46Pro or even a Saito 82 for that plane. The TT is a *very* nice engine (better than the OS in my opinion) but at a lower price and the Saito is just perfect for any 40-sized plane.
Another alternative might be the TT75FS - although I've not had my hands on one yet to verify the claims that they're very good value for money.
When I'm not here, I'm at RCModelReviews
(in reply to freeair)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
