HELP WITH TUINING THE VX-18 FOR BRAKE IN
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> HELP WITH TUINING THE VX-18 FOR BRAKE IN
Page: [1] 2   next >   >>
Login
HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 6:46:49 PM
Cam_132
Status: offline
hi everyone i have a exceed rc nitro buggy it is a fireblack and i have put 3 tanks of fule throgh it and i tryed the fourth tank and it wont start. i think it is the lo-speed nedel (idel) what should the nedels be for brakein... or on this mader how to get it started it could be too lein or too rich... Can you help me!!!!!!!!
_____________________________
Sponcer: Vancouver hobbies,Email westcoasthobbies@shaw.ca
Best of luck to you in your future endeavors - Dr.kliner HL2
       Post #: 1
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 7:58:09 PM
HimotoRacingUSA
Status: offline
if it ran before and not now you should try to check the glow plug or just change it, its common for a glow plug to go bad during break it, i would suggest using an os a3 hot plug.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to Cam_132)
       Post #: 2
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 9:21:25 PM
Cam_132
Status: offline
Ya i have and that is what i am runing...
Well i found it,well... i was chaning the idel speed insteed of the mixture...
how i found out thet was i had to take apart the carb becouse it was jamed and i took it apart and found out the screw i was turning was the idel set screw not the mixture so....
What should the mixture be for a day that is 90 is the humidie and the temp is 77F what should the setings be...
Well for a start...
< Message edited by retard1322 -- 8/29/2007 9:22:12 PM >
(in reply to HimotoRacingUSA)
       Post #: 3
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 9:24:46 PM
HimotoRacingUSA
Status: offline
2 out on high and 3 out on low, within a 1/2 turn each but it will get you up an running
       Post #: 4
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:03:10 PM
Cam_132
Status: offline
ok thank you i will try it if it does not work i will contact you agan
       Post #: 5
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:05:40 PM
HimotoRacingUSA
Status: offline
no problem, that should get you going.
       Post #: 6
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:11:39 PM
Cam_132
Status: offline
THANK YOU IT WORKS... i had too lean it out about 1/2 of a turn from the two turn you recimoneded but it wont stay runing is it just the glow plug???
i will get the O.S. A3 glow plug or should i go one hotter like an A4 or an A5???
But thank you
       Post #: 7
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:14:45 PM
Cam_132
Status: offline
it is about 80F hear in B.c. canada... yesterday it was 65f so it is hot today. i think i have a fouled up glow plug just becouse it wont stay runing...
But thank you. i have been trying to get it to run sinece 7:00pm yesterday and gone throught a tank of wasted gas doing it... thankyou
       Post #: 8
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:16:18 PM
HimotoRacingUSA
Status: offline
i would change the plug, 1 1/2 sounds too lean to me. the a3 is the hottest plug, the a5 is med/cold and i didnt know they made an a4 but the lower the number the hotter the plug.
       Post #: 9
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:20:58 PM
Cam_132
Status: offline
ooh ok i thought it was the lower the num the colder... ok i have an extra A5 plug... so i will swap it... thanks
       Post #: 10
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:40:47 PM
Cam_132
Status: offline
SWEET THANKS IT WORKS GRATE NOW
P.S. it is a fast bugger...
       Post #: 11
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/29/2007 11:41:51 PM
Cam_132
Status: offline
pph one more thing i should add what odonnell glow plug is the same as the O.S. A5
       Post #: 12
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/30/2007 12:02:25 AM
HimotoRacingUSA
Status: offline
the red is hot, yellow is med and probably close to the a5. i am not sure about the other ones, the lower the number the hotter the plug if they have numbers. i like os and pretty much run them or novarossi. i am glad you got it going.
       Post #: 13
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/30/2007 12:24:19 AM
Cam_132
Status: offline
ooh one more thing when i was runing it by the end of the tank i herd a Crunch, Crunch, Crunch, from the clutch bell... well i was moveing well it was off and found you that it was stoping on one point... could it be somthing in the bell...
       Post #: 14
RE: HELP WITH TUINING THE VX-18 FOR BRAKE IN - 8/30/2007 12:35:00 AM
Cam_132
Status: offline
ok never mind it was a peice of woodchip in it now it does not do it any more... i will contact you if i have any more problams...
