RE: *Brillelli 26-SSR*
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  7/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: *Brillelli 26-SSR*
Page: <<   < prev  7 8 9 10 11 12 13 [14] 15 16   next >   >>
Login
RE: *Brillelli 26-SSR* - 7/1/2008 10:57:20 PM
SunShyne
Status: offline
Frank- agree with you
Jake- thanks for the numbers. my only issue is the CAP does not have room for a pipe or anything fancy beyond a pitts/stock muffler so I might have to go with a bigger motor?
_____________________________
www.TheBossIsAway.com
Revver Bro #86
(in reply to Jake Ruddy)
       Post #: 326
RE: *Brillelli 26-SSR* - 7/3/2008 2:00:06 AM
apriliamille
Status: offline
hi,
hey all another question if i could please. i have searched some spinners and figured this is the best variety option (i.e. various type propellors) to get to coincide with my wh baby extra (still waiting on the engine but hopefully it is sooner then later so its not fly ready yet. just accumulating more accessories for that time)
its the tru turn big bird 3 inch which fits up to a zinger 20x10
http://www.truturn.com/cgi-bin/store/agora.cgi?p_id=tt3052b:16&ppinc=spinners160&exact_match=on
is this a wise choice or should i go with a a standard slot or a wide slot?
as this is my first plane and gasser in which i have had to go and choose my spinner, i am not to savvy on the particulars...
is a back plate or lightened back plate needed with the 26? as i dont see this option with the big bird spinner
thanks
mike
(in reply to SunShyne)
       Post #: 327
RE: *Brillelli 26-SSR* - 7/3/2008 2:33:30 AM
Jake Ruddy
Status: offline
quote:
ORIGINAL: SunShyne
Depends what it will weigh... they do have a 36 which is pretty narrow and makes as much power as the old 40
       Post #: 328
RE: *Brillelli 26-SSR* - 7/3/2008 2:37:01 AM
Jake Ruddy
Status: offline
april: I think the standard slot will probably be fine.. you are going to end up running an 18x6 so I think it should fit fine.
The backplate is directly related to CG.. the engine doesn't care. If you could get a lightened I would just because it's easy to move batteries and you will save weight overal. Either way I dont think it's a major decision breaker.
Also you don't need a prop adaptor.. save your money. They 26 is pre taped so all you need is a standard 10 32 bolt that comes with most spinners.
       Post #: 329
RE: *Brillelli 26-SSR* - 7/3/2008 3:09:49 AM
hutchi
Status: offline
anyone heard from scott, no phone calls or e-mail responce. man I need that 26 back
       Post #: 330
RE: *Brillelli 26-SSR* - 7/3/2008 3:09:56 AM
3D_Junkie
Status: offline
April,
Just give the folks at tru-turn a call, tell them what prop you plan on using, they will be able to tell you what cut on the spinner you need. You can get a lightened back plate for a little extra. You will also need to get an 8mm bushing from them, this takes up the space between the hole in the back plate and the motor shaft. There is no prop adapter needed since Scott drills the prop bolt for a 10-32 bolt (which is what tru-turn uses), you may have to shorten the bolt a little but you won't know that until you get the spinner on the plane.
       Post #: 331
RE: *Brillelli 26-SSR* - 7/4/2008 7:26:16 PM
3D_Junkie
Status: offline
Update - Flew today without the cowl. No problems.
I think the combination of cowl and velocity stack is causing the problems that I have been seeing. I will fly tomorrow with the cowl on and velocity stack off and see how it does.
(in reply to 3D_Junkie)
       Post #: 332
RE: *Brillelli 26-SSR* - 7/4/2008 7:32:19 PM
Jake Ruddy
Status: offline
If it acts up like that take a piece of cardboard and build a temp shield infront of the carb. If air is going over the carb the right way it will suck air away from the carb and cause you a world of issues
       Post #: 333
RE: *Brillelli 26-SSR* - 7/4/2008 11:10:45 PM
3D_Junkie
Status: offline
I think I will be good with just removing the velocity stack. I had it like that without a hole in the cowl and it seemed to work. I had added the velocity stack to troubleshoot another issue. I will report back tomorrow once I have flown it.
Also, the motor is a lot smoother with the 17x6 prop and it seems to pull a lot harder. Sometimes bigger is not better.
       Post #: 334
RE: *Brillelli 26-SSR* - 7/4/2008 11:26:09 PM
xtraflyr
Status: offline
quote:
ORIGINAL: 3D_Junkie
HMM? Maybe cuz the motor is getting more rpms so the prop is working more efficiant(sp?)
Cuz my dads was spinning that same prop like crazy. Hopefully we'll get to fly it Sunday and then at the Warbirds Over Delaware!!
Cya,
Frank
www.njjf.org
www.njjf.freeforums.org
       Post #: 335
RE: *Brillelli 26-SSR* - 7/5/2008 12:03:44 AM
LOGRUS
Status: offline
I used prop APC 18x6W@8600 RPM.
I sink it good/ result.
(in reply to xtraflyr)
       Post #: 336
RE: *Brillelli 26-SSR* - 7/5/2008 12:49:04 AM
3D_Junkie
Status: offline
quote:
ORIGINAL: xtraflyr
quote:
ORIGINAL: 3D_Junkie
Cya,
Frank
It is just that these motors really work better when allowed to spool up to the 9000-10000 rpm range. I originally had a menz 18x6 on it that turned 8900 rpm. I think the 17X6 works just a little better, for my setup.
       Post #: 337
RE: *Brillelli 26-SSR* - 7/5/2008 3:36:41 AM
Chefer
Status: offline
Any idea about 3D performance of B26 on a Giles 202UL from Ultra-RC/OMP?
Brillelli's site have a picture of this Ultra Light Giles 76" with a B36GT but I'm thinking in a lighter combo using the 26-SSR.
       Post #: 338
RE: *Brillelli 26-SSR* - 7/5/2008 3:43:21 AM
xtraflyr
Status: offline
quote:
ORIGINAL: Chefer
I havent seen it myself,but I heard their using the B26 with a tuned pipe. I would think the 36 would make the wing loading to high on your Giles.
I would go with the B26,if it was my decision..
My B26ssr is plenty of power in my 17lb. Warbird..
Cya,
Frank
www.njjf.org
(in reply to Chefer)
       Post #: 339
RE: *Brillelli 26-SSR* - 7/5/2008 1:16:51 PM
plasticman
Status: offline
Chefer,
I think a B-26 will work if you keep it as light as possible and use a pipe. Overall, the B-26 will fly anything an O.S 1.60 will if you use a pipe. I had an Ultra-RC Giles and had a B-46 on it. It flew good but was a little too much for the airframe. A B-36 might be just right if you have not purchased yet.
David
Plasticman
       Post #: 340
