jmhh
Joined: 4/17/2007 From: Houston, TX, USA Status: offline
Quote from Srouthouse on Repair Question: figured out what my swashplate vibration was. after a slight blade strike that busted nothing, the upper part of the swashplate was pulling out of the bearing. had my first strong blade strike resulting in the main shaft and feathering shaft and stabilizing shaft being bent. repairs are still under 10 bucks I too seem to be having these same problems, plus my swash plate is not level ....SR, how did you fix the swash problem?..and where are the "feathering shaft" and the "stabilizing shaft"(in the fly bar)? ...my swash is not level and the servo arms for the swash are not in the neutral position as shown in the manual..is this a problem?...if so, how to fix?...and finally,how do you level the swash?...is it supposed to be perpendicular to the main shaft or the ground?...and do you start the leveling process with the lowest control arms for swash servo and then work up the control arms toward the blades?...thanks for any assistance John H. LEARNING TO FLY BY LEARNING TO REPAIR
