srouthouse
CA, USA Status: offline
im using the 65HG and upon stripping them if and when ill go to MG the HG,s are 25 bucks. use the 9g,s for now,youll get past the wrecking all the time stage pretty quick anyway. if you must upgrade get the HS65,s that way you can use them on any of the helis you will get and youll have the best. i bought the HS65,s from mike great service, they stayed in there box and i finaly popped them in my trex cause the 9g,s were working so good. yes the 9g,s stripp quick but you can use your tail servo for replacement. i do reccomend a better tail servo. ive only had to buy 2 9g,s and i wreck allot make sure you get all 3 servos the same.
