RE: The Better HeliPro Black Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: The Better HeliPro Black Hawk
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: The Better HeliPro Black Hawk - 10/12/2007 7:40:49 PM
MiniCwik
Status: online
Yeah, which is the way it seems to me to happen ... and just keeps blowing my mind more and more.
I'll be home in an hour or so to look and will comment then also.
_____________________________
Nitro Trk - Himoto Eldorada 1:10 4WD (w/upgrades)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE v1 (2100T/9257)
(in reply to USHobbySupply)
       Post #: 76
RE: The Better HeliPro Black Hawk - 10/12/2007 11:25:33 PM
ea01bg
Status: offline
Mini Cwik,
I had a hard time with it drifting a bit after a crash, I had one form a Trex I was working on so I just changed it out. During the same tme mike suggested checking that the tail hadnt twisted at all it had move a bit and I straightened it so I'm not sure if the gyro was the problem. Later (after the rest of the parts arrived0 I put that gyro on the trex and have been trying to get the setup right, The tail seems to be holding fine but I havent done more than some short hover / hops.
(in reply to MiniCwik)
       Post #: 77
RE: The Better HeliPro Black Hawk - 10/13/2007 1:54:30 AM
MiniCwik
Status: online
Does anyone know how to remove the tail hub from the shaft???
I need to get that off to replace a part that broke and removed the grub screw but it's not budging ... help?
Spoke with Mike at Ka-Planes, who thinks that my gyro is bad and is sending me a new one ... through testing the tail pitch yoke plate (with the eye bolts) broke so I am needing to replace that - HP05-P018 is the P/N. Mike is a great guy and I highly recommend him, his service is A+!
(in reply to ea01bg)
       Post #: 78
RE: The Better HeliPro Black Hawk - 10/13/2007 2:10:39 AM
ea01bg
Status: offline
This might help
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 79
RE: The Better HeliPro Black Hawk - 10/13/2007 2:45:51 AM
MiniCwik
Status: online
I have the manual to see how it goes together, but how do you get that dang hub piece off?
There is loctite down in there ... do I heat it up to loosen it?
       Post #: 80
RE: The Better HeliPro Black Hawk - 10/13/2007 3:08:41 AM
MiniCwik
Status: online
OH nevermind, my bad ... I got it ... put a little butane to it and wallah it practically fell off.
Thanks bro!
       Post #: 81
RE: The Better HeliPro Black Hawk - 10/13/2007 3:21:21 AM
TomOver
Status: offline
That was a good idea, I will have to keep that in mind. That was for thread-tite not CA correct?
       Post #: 82
RE: The Better HeliPro Black Hawk - 10/13/2007 3:27:21 AM
MiniCwik
Status: online
Correct TomOver I have a small butane torch and just hit it for a few seconds and it was off like gravy
Can't wait to get the gyro replacement and tail pitch replacement and get this heli airborne
(in reply to TomOver)
       Post #: 83
RE: The Better HeliPro Black Hawk - 10/13/2007 7:32:15 PM
TomOver
Status: offline
thanks I will try that on metal parts the next time I need to.
       Post #: 84
RE: The Better HeliPro Black Hawk - 10/13/2007 10:47:03 PM
PaulLee
Status: offline
use CA releaser spray for CAd parts
       Post #: 85
RE: The Better HeliPro Black Hawk - 10/14/2007 1:10:20 AM
Helihap
Status: offline
Gyros are definitely a key factor and I think a good one is very important. Futabas and Telebee/Align are a couple of the well known ones.
(in reply to PaulLee)
       Post #: 86
RE: The Better HeliPro Black Hawk - 10/15/2007 12:16:52 AM
TomOver
Status: offline
Agree, but what were you responding to?
(in reply to Helihap)
       Post #: 87
RE: The Better HeliPro Black Hawk - 10/15/2007 12:59:28 AM
MiniCwik
Status: online
Has anyone gone through tail pieces quickly? I've snapped tail blade grip (tips) and the pitch piece that has the eyelets connected to it.
Is there a T-rex compatible replacement? Or a metal upgrade for these pieces?
I'm waiting on a replacement gyro from Ka-Planes and will have it all working soon ... and cannot wait!
       Post #: 88
RE: The Better HeliPro Black Hawk - 10/15/2007 1:05:03 AM
TomOver
Status: offline
the pitch slider on the metal tail also has the plastic that the eyelets screw into. You could replace the tail assy with an all metal rex one. However, once you get this thing going you should be ok.
