RE: The Better HeliPro Black Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: The Better HeliPro Black Hawk
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: The Better HeliPro Black Hawk - 10/19/2007 9:31:28 PM
MiniCwik
Status: offline
Thanks Mike!!!
I can't wait for the winds (20+) to subside so I can get more outdoor flights in
This is an excellent heli!!!
Did you get my order just placed
_____________________________
Nitro Trk - Himoto Eldorada 1:10 4WD (w/upgrades)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE v1 (2100T/9257)
(in reply to mikek0416)
       Post #: 101
RE: The Better HeliPro Black Hawk - 10/19/2007 9:35:58 PM
mikek0416
Status: offline
It is indeed excellent. Yes, I just saw your order and Diana is processing it. Enjoy and my sincere thanks
Mike
(in reply to MiniCwik)
       Post #: 102
RE: The Better HeliPro Black Hawk - 10/19/2007 10:44:49 PM
ea01bg
Status: offline
MiniCwik ,
Did you pick up the tail from USHobbySupply.com ? Did it come as the whole assembly or parts , could you provide links or part numbers.
Brian G
       Post #: 103
RE: The Better HeliPro Black Hawk - 10/20/2007 1:01:48 AM
Helihap
Status: offline
microheli brand has about the best and they match, but align has the blue system that is sharp too.
       Post #: 104
RE: The Better HeliPro Black Hawk - 10/20/2007 9:15:14 PM
TomOver
Status: offline
I think if you do not over torque the gold cylnder to the plastic flange it will caise less stress on the flange keeping it from busting. I did replace one and haven't had a problem since. Mr M helped me.
(in reply to Helihap)
       Post #: 105
RE: The Better HeliPro Black Hawk - 10/21/2007 1:49:19 PM
MiniCwik
Status: offline
quote:
ORIGINAL: ea01bg
MiniCwik ,
Brian G
Yes, it was assembled and it's here - http://www.ushobbysupply.com/product_info.php?cPath=31_33&products_id=215
I Love it, Love it!!!!
(in reply to ea01bg)
       Post #: 106
RE: The Better HeliPro Black Hawk - 10/21/2007 8:42:10 PM
SteveCink
Status: offline
Does anyone have the basic DX6 settings to get me started or can I use another helicopters settings if I can find them? Thank you
       Post #: 107
RE: The Better HeliPro Black Hawk - 10/21/2007 9:09:21 PM
ea01bg
Status: offline
Here is the settings Mike from KA-Planes sent me. I have not tried them yet.
I will not be near the DX6 for a couple of days but have some basic programming here on my laptop, I think someone gave me them one time for another heli but most of the settings looks the same or at least similar.
Channels
RUD rev
GER normal
PIT rev
THR normal
AIL normal
ELE rev
______________________________________
D/R
AIO 100% AI1 100%
ELO 100% EL1 100%
_________________________________________
EXP
AIO 0%
ELO 0%
SubTrim
Adjust these as appropriate
__________________________________________
TRV ADJ
Ger - 45% + 45% when switching to rate mode on D/R switch
PIT -100% +100% from low to high throttle
AIL -100% +100% cyclic left to cyclic right
ELE -100% +100% cyclic down to cyclic up
RUD - 75% + 74% To adjust servo travel on tail servo, it varies
_______________________________________________________
HLD 0% - or down to -5 for autorotation like the manual indicates
PLN 25% P2N 59% PHN 100%
PLS 0% P2S 50% PHS 100%
PLH 0% P2H 50% PHH 100%
TLN 0% T2N 65% THN 100%
TLS 100% T2S 80% THS Factory set at 100% (its not shown on the screen)
Mix
RVU 0% RVD 0%
AII 0%
AII offset 0
Ach 11
ASW on
CCP ON
CP2 +45%
CP3 + 45%
CP6 + 40%
The one thing in particular is note the throttle setting is normal whereas with lots of other systems it is REV
(in reply to SteveCink)
       Post #: 108
RE: The Better HeliPro Black Hawk - 10/21/2007 9:26:12 PM
SteveCink
Status: offline
Thanks , do you know if they were for the 450 or generic? Once I get this going by next weekend I hope, I will let you know how it went.
       Post #: 109
RE: The Better HeliPro Black Hawk - 10/21/2007 11:28:25 PM
ea01bg
Status: offline
not sure.
I'm waiting until winter sets in to swap mine out.
       Post #: 110
RE: The Better HeliPro Black Hawk - 10/22/2007 4:00:09 AM
SteveCink
Status: offline
I think once you get the servos going in the right direction you need to ensure the CP settings at the end are coordinated. Will find out......
       Post #: 111
RE: The Better HeliPro Black Hawk - 10/24/2007 1:02:50 AM
TomOver
Status: offline
Its a pretty standard series of settings. You can almost set up with the default and with some trial and error on the reversing of servos can get there fairly quick. Just be cautious with the throttle setting, normal seems to be the standard whereas a lot of systems you use reverse.
       Post #: 112
RE: The Better HeliPro Black Hawk - 10/26/2007 11:08:10 AM
PaulLee
Status: offline
I went to large field and flew in good breeze with no problem. I keep rotation speed good and not real sharp turns. About to move more south so maybe better flying.
(in reply to TomOver)
       Post #: 113
RE: The Better HeliPro Black Hawk - 10/26/2007 11:52:15 AM
MiniCwik
Status: offline
That's cool PaulLee, you know how I was asking you about connecting the lipo battery monitor over on RCG?
Do you think I could just solder a male Deans to the lipo monitor and then get a dual female to male Deans adapter to connect to the battery? I think I will go that route (since I already cut off the small red connector from the monitor (dohh)).
Like this;
< Message edited by MiniCwik -- 10/26/2007 12:35:40 PM >
(in reply to PaulLee)
