RE: The Better HeliPro Black Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: The Better HeliPro Black Hawk Page: <<   < prev  51 52 [53] 54 55 56 57 58 59 60   next >   >>
Login
RE: The ... - 4/27/2008 2:00:42 PM
Edwinssiv
Status: offline
You may be able to replace the rotor head with the GazaurRotor Head...there are shops that support this heli
_____________________________
Blade CX2/Axe CP/ Trex 450 SE v2/Gazaur Mars 480
(in reply to Edwinssiv)
       Post #: 1301
RE: The ... - 4/27/2008 6:29:13 PM
HeLiTuBBies
Status: offline
i broke a heavy duty spindle shaft... i broke a screw in half, the other half of the screw is stuck to the rotor grip... i barely got the heli off the ground, now it's down... blackhawk down! didnt even had the chance to fly it outside.. i hope i get some parts for it ..i did throttle down immediately..it was too late, it hit zimba (stuff toy). it's a stupid mistake.. trying to hover on an 8 foot square area is very stupid.. i got lucky, mike at ka-planes sells the spindle shaft, nobody sells the other parts for my heli.. Thats what i get for buying a limited version of BH450 anybody has an idea how to take a broken screw out of the grip?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1302
RE: The... - 4/27/2008 8:31:15 PM
Edwinssiv
Status: offline
HeLiTuBBies...I posted two post for you to look and see if you can replace the head from Gazaur line of helicopters or get parts maybe...did you look at the links?
(in reply to HeLiTuBBies)
       Post #: 1303
RE: The... - 4/27/2008 8:54:43 PM
HeLiTuBBies
Status: offline
that gazaur parts are similar to what i got... hmmmm.. the whole rotor head assembly is almost identical to what i got... Thanks Ed
       Post #: 1304
RE: The... - 4/27/2008 11:01:23 PM
Kaelan
Status: offline
I hope the gauzer parts fit for you. that head and grip on your BH is nothing like what we all have. as far as getting the screw out. if there's anything sticking out, try carefully gripping it with a set of needle nose. if not, drill it out VERY carefully. then of course you'd need a tap and die set to rethread the hole.
oh yeah.. these heli's are to big to try and fly inside. you got lucky it was only a toy that got hit. it could ahve been much much worse
Gaui Hurricane 550 CF
HeliPro BlackHawk 450SE
       Post #: 1305
RE: The... - 4/28/2008 12:34:05 AM
HeLiTuBBies
Status: offline
here is the pic of my rotor head, of course there would be no use for it if i cant use my rotor grips due to that broken screw. The part is nowhere to be found online unless mike can special order it for me. its a floating type rotor, i guess helipro decided to use their neighbor's rotor head on this version . Here are my options, the 2nd photo for 99$ or the 3rd photo for 172$ .. wish me luck
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by HeLiTuBBies -- 4/28/2008 12:57:14 AM >
(in reply to Kaelan)
       Post #: 1306
RE: The ... - 4/28/2008 12:46:05 AM
rocket-ron
Status: online
quote:
ORIGINAL: HeLiTuBBies
Is there a machine shop in your area? A good machinest could remove that (broken shaft) for way less than 90.00! My first thoughts were"i'd replace the head/swash,with a regular BH head/swash parts,but if Mike has the shaft,I would take the blade/grip to a machine shop,or tool & die maker,if any are around. It would be a simple job for them. Ron
< Message edited by rocket-ron -- 4/28/2008 12:48:34 AM >
       Post #: 1307
RE: The... - 4/28/2008 1:28:50 AM
HeLiTuBBies
Status: offline
Does mike has the spindle shaft? yes and no.. although the shaft he sells has the same part number with the one i got, i just found out by comparing the photos that his is diferent.. his uses a nut to lock the grips and mine uses a screw to lock it. outside thread and mine has inside thread.. male or female i guess yes i did thought about converting it to a usual BH rotor head but mike only has the stock rotor parts and not the pro version, his main shaft is different too .. even if i can get it converted after a few more parts replaced, it still means i'll be downgrading getting the gazaur rotor head set to fit means i would have plenty of parts available if i trashed my heli again after i fixed it.. Floating type rotor system has less parts, i kinda want to try my luck with it .. lol
(in reply to rocket-ron)
       Post #: 1308
RE: The... - 4/28/2008 2:00:19 AM
Kaelan
Status: offline
you could always convert it to a Trex head. Mike has the complete head available. the plus side would be that parts for the head are available just about everywhere.
       Post #: 1309
RE: The... - 4/28/2008 2:29:35 AM
HeLiTuBBies
Status: offline
that sounds interesting bro..hmm the servo positions on the blackhawk would work on trex's swashplate? how about the main shaft, main gear does it need to be replaced too? i might consider that.. how much do you think it will cost me .. parts+labor? i'll just probably send my BH to mike then..
       Post #: 1310
RE: The... - 4/28/2008 2:51:47 AM
HeLiTuBBies
Status: offline
Black hawk Got stripped!
Click for fullsize
Click for fullsize
< Message edited by HeLiTuBBies -- 4/28/2008 2:54:43 AM >
       Post #: 1311
RE: The... - 4/28/2008 3:03:51 AM
noobflyer01
Status: online
where did you get that blackhawk from? what about getting the bare bones se version for 199? you could use all that spare parts for later crashes. that's what i did with the HBK2. i got two bare bones kit for spare parts. my king 2 is never down for long. all the spare parts is just sitting there waiting. . well i'm picking up my Bh450 on monday morning with all the bling added. cant wait to see how she flys now.
EF mash rescue Co-ax, HBK2, HBFP, Belt CP, Blackhawk 450, EXI 450, trex 450 SA, mars 480, mini titan e325
       Post #: 1312
RE: The... - 4/28/2008 3:29:11 AM
